problem during swap
Old Jun 8, 2002 | 06:04 PM
chipper's Avatar
Default problem during swap
there are 2 lines off the back of the transmission that were cut on the b16. on the d16 these lines are not there. what are these hoses for?? what should we do with them??
its on the back side of the tranny and is mounted upward, there is a connection from the firwall into the middle and 2 lines on either side of the firewall piece (im not sure what it is)
Old Jun 8, 2002 | 09:32 PM
keebler65's Avatar
Default Re: problem during swap (chipper)
you're referring to the speedometer sending unit. on your b16 there's probably 3 hoses coming from it. the middle one (the cable) is the one that goes through the firewall and to your speedometer. the other two are for power steering which you wont need. i just looped them together so that there were no open ends. do as you wish. i know some ppl just use the one off of their old motor instead.
Old Jun 8, 2002 | 09:37 PM
EF_LSVtec's Avatar
Default Re: problem during swap (keebler65)
He's right
x95civicb16
44
Nov 26, 2012 07:46 PM
91crx-si
Oct 22, 2008 05:53 PM
dunkd
11
Apr 22, 2005 10:18 AM
bigblueandyellow
Dec 20, 2004 06:27 AM
rice_classic
Jul 4, 2002 08:14 PM
