Cage for prelude.
Actually I know where i can get one stuck in for around 500... I would rather find a kit off the net and just weld it in to keep cost down....form doesn't matter here, just function. I looked in jegs....but nothing really looked the part.
You're not going to a find a cage worth a damn for $500 for less. Autopower is probably going to be the cheapest adequately built cage, and IIRC, they run just under $800 for the bolt in cage.
I haven't seen any weld together kits, except Autopower's kit that allows you to weld the front half to one of their roll bars, but I don't think you'll be able to get that for less than $500.
You certainly aren't going to get a custom cage for $500.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">You're not going to a find a cage worth a damn for $500 for less. Autopower is probably going to be the cheapest adequately built cage, and IIRC, they run just under $800 for the bolt in cage.
I just orered a 6 point with a LOT of extra diagonals from i-o port (autopower distributor) and it was about $1100 shipped. Their basic 4points is probably going to be about about $600 shipped. Good cages and If your only looking for a 4 point your not going to need anything more than their cage.
</TD></TR></TABLE>I just orered a 6 point with a LOT of extra diagonals from i-o port (autopower distributor) and it was about $1100 shipped. Their basic 4points is probably going to be about about $600 shipped. Good cages and If your only looking for a 4 point your not going to need anything more than their cage.
I think maybe he meant roll bar, not a cage. 4 point cage would be silly. for a cage you need at least 6 point. Autopwer sells a good 4 point roll bar that is SCCA hill climb legal.
Yours was just a little more than that right?!?!
</TD></TR></TABLE>Yours was just a little more than that right?!?!
The only reason I am going to go with a four point is that is what the series mandates....i could go more but then I'm driving a heavier car than I started with, I want to be competitive at the least. It's only a dirt car that will run in the 75 mph range...I think I will be fine with the smaller cage.
275Performance
May 1, 2003 02:43 PM
