Brake question
Old Jul 12, 2007 | 09:29 PM
B bOy CrAyOn's Avatar
Default Brake question
my 93 hatch has integra rear disc brake swap but they never put a gsr integra master brake cylinder and brake booster...... i have a set of 00 SI front brakes sitting here and should i just find a set of integra fronts for my hatch also or just use the 00 SI brakes for the front brake swap.... and last question, so does the gsr master brake cylinder and booster swap right on to my hatch with no mods and if so does it have to be from a certain year integra ?
thanks for the info ahead of time
Old Jul 12, 2007 | 09:31 PM
another question is what is the average price people sell the gsr master brake cylinder and booster for ?
Old Jul 12, 2007 | 10:46 PM
realblag's Avatar
Default Re: Brake question (B bOy CrAyOn)
The part you need is the proportioning valve. The master and the booster will give more solid braking with less pedal, but the prop valve will make the front/ rear bias correct. This is all assuming the car did not have rear discs stock.
Old Jul 12, 2007 | 10:48 PM
bmoua's Avatar
you'll be fine with the si front brakes bro, I'd suggest you get the prop valve/mc/booster installed first before you do the front brake upgrade though.
Old Jul 12, 2007 | 11:39 PM
roastbeefrichie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B bOy CrAyOn &raquo;</TD></TR><TR><TD CLASS="quote">my 93 hatch has integra rear disc brake swap but they never put a gsr integra master brake cylinder and brake booster...... </TD></TR></TABLE>Quote, originally posted by BrakeExpert&gt;&gt;"When you go to bigger caliper than use a larger piston, you are pushing more fluid through the brake lines. Therefore, you should want a larger master cylinder to push this more fluid. General rule is…with your stock Civic DX, with the stock front calipers, keep your 13/16” MC. Any bigger and your pedal will be too stiff."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B bOy CrAyOn &raquo;</TD></TR><TR><TD CLASS="quote">...... i have a set of 00 SI front brakes sitting here and should i just find a set of integra fronts for my hatch also or just use the 00 SI brakes for the front brake swap.... </TD></TR></TABLE>the 99-00 civic si calipers or 94-00 integra calipers won't work on DX knuckles. unless you have swapped out your knuckles, chances are that you have the DX w/ 9.4" rotors. to use the 99-00 Si (or 90-00 integra) calipers, swap your knuckles for 94-00 integra front knuckles w/ 10.3" rotors
https://honda-tech.com/zerothread?id=820484
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B bOy CrAyOn &raquo;</TD></TR><TR><TD CLASS="quote">.... and last question, so does the gsr master brake cylinder and booster swap right on to my hatch with no mods and if so does it have to be from a certain year integra ?</TD></TR></TABLE>the booster isn't neccessary, your stock oem civic master brake booster will do just fine. upgrading your master brake cylinder, you'll want non-abs...ask for: 94 integra rs, 90-93 integra, or 90-91 civic ex.
https://honda-tech.com/zerothread?id=364783
*if you don't want to swap integra knuckles, you could always use integra type-r calipers on DX knuckles w/ 10.3" rotor
https://honda-tech.com/zerothread?id=1484555
&gt;&gt;pm BrakeExpert, he machines brackets & he'll set you up w/ awesome brakes
Modified by roastbeefrichie at 3:49 AM 7/13/2007
Modified by roastbeefrichie at 3:59 AM 7/13/2007
Modified by roastbeefrichie at 4:10 AM 7/13/2007
Old Jul 13, 2007 | 12:06 AM
Default Re: Brake question (roastbeefrichie)
OR keep your current set-up and get new pads & blank rotors, always works for me. if you got money to spend, good brake fluid & ss lines
Old Jul 13, 2007 | 12:15 AM
first things first...yes, you need one
Old Jul 13, 2007 | 04:33 AM
methos713's Avatar
good info w/ links
Old Jul 13, 2007 | 12:57 PM
thanks alot yall.. more info than i expected to get
Leb_CRX
Jan 31, 2005 08:40 PM
B HATCH
11
Apr 15, 2004 05:07 PM
scoobyghost
Jul 14, 2003 10:17 AM
Kronic
Jun 6, 2003 02:17 PM
