T4/to4e how much hp
Old Jul 12, 2007 | 07:03 PM
high_octane's Avatar
Default T4/to4e how much hp
ok i just blew my t4/t67 turbo and got a t4/t04e for $200 buck, i need to know how much hp i can make out of this turbo...my step is a fully built b18c1 benson sleeves, 1000cc injectors, runing on hondata s300 made 400hp on a mustang dyno on 18psi. Now is it worth it to run this turbo or spend another grand for a new turbo?
Old Jul 12, 2007 | 08:49 PM
BoostedGreddy's Avatar
Default Re: T4/to4e how much hp (high_octane)
400-450
Old Jul 12, 2007 | 11:15 PM
quicksilver1689's Avatar
i ♥ snails
your a retard
Old Jul 12, 2007 | 11:27 PM
Doostur's Avatar
^ Why?
Old Jul 13, 2007 | 01:19 PM
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">your a retard</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by high_octane &raquo;</TD></TR><TR><TD CLASS="quote"> i need to know how much hp i can make out of this turbo...</TD></TR></TABLE>
He asked how much he can make out of the turbo. NOT the motor.
Old Jul 13, 2007 | 01:27 PM
ndogg's Avatar
depends on the specs on that turbo. why are you running a t4 hotside at only 400 hp?
Old Jul 13, 2007 | 03:51 PM
blinx9900's Avatar
Default Re: T4/to4e how much hp (ndogg)
if the turbo has stage 5 wheel and a .82 hot side it should generate enough air for 475whp.
p.s. most t3t/o4e turbos have s tage 3 wheel and .63 housing.
edit: never mind is see you have a t4/to4e.
Old Jul 13, 2007 | 04:10 PM
the reason why i only tune for 400hp was to break in the motor an so i can get use to 400hp b4 i turn the boost up... i was driving on the highway an my oil pump went out an then my turbo went out. U guy think i can atleast make 500hp out of this turbo?
Old Jul 13, 2007 | 07:12 PM
i ♥ snails
ok there is more than one t3t04 my friend
Old Jul 13, 2007 | 07:14 PM
i ♥ snails
and if your looking for more than 500hp this is not your turbo.
Old Jul 13, 2007 | 07:40 PM
Joseph Davis's Avatar
Default Re: T4/to4e how much hp (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">if the turbo has stage 5 wheel and a .82 hot side it should generate enough air for 475whp.</TD></TR></TABLE>
Stage 5 wheel and .63 AR turbine housing will do 475 if you don't give a expletive and crank the boost controller like you have a pair. Pushing 30-31 psi I had an SC44 putting 470-477 whp more or less flat as a strap from 6800-9500 on an 84mm ITR - that was fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">and if your looking for more than 500hp this is not your turbo.</TD></TR></TABLE>
Nonsense! That's what nitrous is for!
Old Jul 13, 2007 | 08:34 PM
blinx9900's Avatar
Default Re: T4/to4e how much hp (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">
yeah but arent you overspooling the turbo at that point and reducing its life? a .82 swap is just so easy, i dont see why you wouldent do it.
Old Jul 13, 2007 | 08:54 PM
Meh, it's not terribly far off it's published compressor map, so given engineering tolerances I'd say that the lifespan reduction is definitely measurable but not drastic. I could be wrong, but I'm pretty sure for a trailered racecar the turbo will last a couple years.
FYI, the turbo in question has been beat on for ~3-4 years now and was already smoking on decel. The car has a couple track events under it's belt since it was boosted from 411 to 477 and the turbo isn't smoking any worse yet. I'm as curious as you are to see how long it holds together.
Old Jul 13, 2007 | 09:22 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Meh, it's not terribly far off it's published compressor map, so given engineering tolerances I'd say that the lifespan reduction is definitely measurable but not drastic. I could be wrong, but I'm pretty sure for a trailered racecar the turbo will last a couple years.
FYI, the turbo in question has been beat on for ~3-4 years now and was already smoking on decel. The car has a couple track events under it's belt since it was boosted from 411 to 477 and the turbo isn't smoking any worse yet. I'm as curious as you are to see how long it holds together.</TD></TR></TABLE>
impressive one question though, why not swap to the .82? wouldent it give you a little more (if not a lot more) top end? are you keeping it cause you have an excellent tq curve?
Old Jul 14, 2007 | 08:53 AM
thank for all the commet guy...i have a .82 hot side on it....if this turbo can get me to atlest 500hp ill be happy...its going to get dyno in a week so will see how much it can pust out.
Old Jul 14, 2007 | 09:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">impressive one question though, why not swap to the .82? wouldent it give you a little more (if not a lot more) top end? are you keeping it cause you have an excellent tq curve?</TD></TR></TABLE>
The car is together, running, and all our problems are suspension and traction related. Given the time limits the car owner keeps running into between events a housing swap isn't in the cards. You know how it goes.
CustomX113
Nov 20, 2006 09:27 AM
the4ork
Mar 23, 2006 04:02 PM
mrx
Oct 15, 2005 08:32 PM
deeweezy
Nov 8, 2003 07:57 AM
B18c1turboedEK
Aug 15, 2003 01:18 PM
