Info for those w/ modded harness and initial no start w/ MSD distributor
Old Jul 12, 2007 | 05:45 PM
Jared's Avatar
Default Info for those w/ modded harness and initial no start w/ MSD distributor
Ok, in case this happens to you. Car I'm working on no longer has internal coil or ignitor. The blk/yel wire in the harness to the distributor was removed as a result and used to power the ign box. Car ran fine, switch to MSD distributor, no start, no sync, no rpm signal. The MSD distributor uses hall sensors which need power to work unlike the Honda reluctors. Long story short, the MSD dizzy needs power at that blk/yel wire pin in order to output a signal on the three sensors. Just in case this happens to someone else. That is all.
Old Jul 12, 2007 | 06:31 PM
Boostfed's Avatar
New User
Default Re: Info for those w/ modded harness and initial no start w/ MSD distributor (Jared)
You're such a goo guy Jared
lunatics209
Aug 8, 2008 03:41 PM
Tony the Tiger
Jul 18, 2008 11:34 AM
b16hatche
Dec 14, 2005 07:31 PM
94gsr
Jun 1, 2004 12:55 PM
Wiseguy619
Oct 19, 2003 12:25 PM
