Headlight Question
Old Jul 12, 2007 | 05:35 PM
k e v i n's Avatar
Default Headlight Question
I just got a repair order so I need to fix this...
The plug that goes on to the lightbulb slides off alot so my headlight goes out. Is there any way to make it stay on? I tried to tape it on but that only worked for about an hour...
Old Jul 12, 2007 | 05:41 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Headlight Question (k e v i n)
Try a replacement bulb socket. They are only a few bucks at Kragen, Autozone, etc.
97Ej6mike's Avatar
are you sure your plugging it in all the way?
Maybe the the bulb itself has bent/worn plugs, preventing the harness from securely staying on. Usualy headlight plugs are on very snug.
Old Jul 12, 2007 | 05:45 PM
blk2mid2sol's Avatar
you could just pull the connecting wires out of the harness and tighten them so they will bite onto the prongs
Old Jul 13, 2007 | 12:17 AM
NOFX's Avatar
H-T White Ops
You're probably either not putting it on all the way or the plug is broken. My car and my last one actually had the problem that they would stick sometimes.
dlewis2583
Lighting
Oct 26, 2010 05:55 PM
Senbonzakura
Jan 4, 2005 07:48 PM
wildstallion
Oct 17, 2002 05:52 PM
