HELP with type r header
Old Jul 12, 2007 | 04:13 PM
beefy's Avatar
Default HELP with type r header
help i have a type r header and and the flang on that is ******* huge my mid pipe is off a 97 ex what mid pipe will i need and will my muffler still bolt up help me need my car on the road asap
Old Jul 12, 2007 | 04:18 PM
slowcivic2k's Avatar
Default Re: HELP with type r header (beefy)
You should be able to find a 2 1/2" ball flange at a hardware store exhaust shop might even have one. I would use an Omnipower test pipe simply because its clockable and extendable.
I don't know if the US GSR's or Type R's use the 2.5 collector or not, don't see too many stock ones floating around, my guess would be no because US is considered 2.25" and JDM is considered 2.5".
Modified by slowcivic2k at 7:30 PM 7/12/2007
Old Jul 12, 2007 | 04:27 PM
highroller54's Avatar
Default Re: HELP with type r header (slowcivic2k)
http://www.kteller.com
Old Jul 12, 2007 | 04:39 PM
egsleepercivic's Avatar
you could go any muffler shop and have them put a 2.5 flange on your cat
Old Jul 12, 2007 | 04:51 PM
beefy's Avatar
so if i get the oni test pipe or a test pipe will i be able to use what i have now or would i need a new midd pipe
Old Jul 12, 2007 | 05:03 PM
The Omnipower pipe is clockable to fit the flange, you don;t have to panic about it being too short or it clocking the wrong way. It will bolt up to a factory style exhaust, or replacement exhaust with a similar three bolt pattern as factory. If you had a catalyst on your midpipe, then the Omnipower pipe will work just fine.
Old Jul 12, 2007 | 05:06 PM
hatch96y7's Avatar
i just went to my exhaust shop and i got brand new 2 1/2 inch piping.
sounds much better just get it all the way back ull be happy.
i want to know a question after the cat does it matter how much bigger the piping is.
Old Jul 12, 2007 | 06:38 PM
beefy's Avatar
Default Re: HELP with type r header (hatch96y7)
i am kind just looking for all bolt on stuff if i can find it a shop is last resort
recon23
Oct 22, 2008 05:24 AM
NsX_CrX
May 21, 2006 01:41 AM
the soL that could
Mar 14, 2006 09:12 AM
tonezilla
Welding / Fabrication
Feb 15, 2005 07:17 AM
toEknEEg
Mar 7, 2004 03:18 PM
