91 civic b18 swap
Old Jul 12, 2007 | 02:30 PM
crxricer66's Avatar
Default 91 civic b18 swap
i have been researching this and i think i pretty much have it figured out. i need to use the wiring harness from the integra which plugs right into the civic right?? then the ecu from the integra. i need different motor mounts or just fabricate them a lil bit. also will a d15 tranny bolt onto a b18??? thx for all your help
Old Jul 12, 2007 | 06:17 PM
abnaasefmb's Avatar
Default Re: 91 civic b18 swap (crxricer66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">i have been researching this and i think i pretty much have it figured out.</TD></TR></TABLE>
you're all over it
Old Jul 12, 2007 | 06:31 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">also will a d15 tranny bolt onto a b18??? thx for all your help</TD></TR></TABLE>
Umm......NO.
Old Jul 12, 2007 | 06:47 PM
abnaasefmb's Avatar
Default Re: 91 civic b18 swap (SIred91)
what do you mean no? you just need a b to d kit.
Old Jul 12, 2007 | 07:09 PM
crxlsman's Avatar
Default Re: 91 civic b18 swap (abnaasefmb)
or you could just find a b series tranny instead of converting it over to a d series. It'll be a better choice trust me.
Old Jul 12, 2007 | 07:12 PM
abnaasefmb's Avatar
Default Re: 91 civic b18 swap (crxlsman)
i'm not sure if you can just use the teg harness if you do that
Old Jul 12, 2007 | 08:07 PM
birdricer's Avatar
You need a b series tranny, different motor mounts, modified shift linkage, integras axles, PR4 ecu, original civic harness that was on your d series, plug it all up and the only thing you need to do is wire it up for MPFI, if it isn't already. also a bunch of dumb **** along the way will happen.. (happened to me)
Old Jul 12, 2007 | 08:08 PM
midwestdan's Avatar
you will need the integra wiring har.
and if your going obd0 to obd2 gonna hav to do some hard wiring to match it up correctly
Old Jul 12, 2007 | 08:11 PM
abnaasefmb's Avatar
Default Re: (birdricer)
Humm, that’s a lot of ****. I wonder if anyone has ever documented this swap to use as a reference?
Old Jul 13, 2007 | 05:10 AM
gursh d's Avatar
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">Humm, that’s a lot of ****. I wonder if anyone has ever documented this swap to use as a reference?</TD></TR></TABLE>
ryan at rywire has a great write-up on his website. He documented his JDM B18C swap a couple years ago. It's all here:
http://www.droppedcrxsi.com
Old Jul 13, 2007 | 06:22 AM
spastik's Avatar
Default Re: (91.crx.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si &raquo;</TD></TR><TR><TD CLASS="quote">
i think that was sarcasm. at least i hope it was
Old Jul 17, 2007 | 09:11 AM
JAPANMUSCLE's Avatar
what oem mounts can you use for the ls into a hatch or do you have to go aftermarket?
Old Jul 17, 2007 | 09:14 AM
wiZCo's Avatar
Stouts 'n' Scotch
Ahh the sarcasm in this thread is tasty.
It was said before, but you need to do more research.
Start by searching "MPFI swap" on here to get going on the wiring, it's going to be easier to modify your existing harness.
birdricer listed all the hardware you'll need.
Good luck
Old Jul 17, 2007 | 12:42 PM
D16Z6racing's Avatar
Default Re: (wiZCo)
http://www.angelfire.com/d20/h....html
http://www.hasport.com
http://www.hmotorsonline.com
...and you have a lot of searching to do.
agendadjs
Nov 24, 2007 11:09 PM
EncoEvolution
Sep 29, 2005 05:07 PM
NinjaTech
May 31, 2005 02:49 PM
CRseXy
11
Oct 1, 2004 03:20 PM
CRX-RX
10
Mar 23, 2004 01:36 PM
