Snapped stud replacement?
Old Jul 12, 2007 | 01:52 PM
CheeseCake's Avatar
Default Snapped stud replacement?
What is the way to go about a snapped stud on the front right of a 1990 4 door civic (ef)?
Do I have to pull the hub off of the car to replace it? Or would it be easier to just buy a hub from a scrap yard and do a quick replacement? I was told that maybe I couldbang it out straight and bang in a new stud.
Thanks in advanced!
MiKe
Old Jul 12, 2007 | 02:05 PM
gator88's Avatar
Default Re: Snapped stud replacement? (CheeseCake)
you have to remove the hub, press it out with an arbor press or shop press, and then press the new one in. atleast thats what I did for a buddy, hope i didnt remove it for no reason, lol
Old Jul 12, 2007 | 02:07 PM
CheeseCake's Avatar
Default Re: Snapped stud replacement? (gator88)
Is it hard to remove the hub on this generation?
Old Jul 12, 2007 | 02:36 PM
BILLETGRIP's Avatar
can you not just knock it out with a hammer and slide a new one in and pull it through with a lug nut? i know its a little crude but in a pinch i dont see why you couldnt. unless theres not enough room to get the old one out and the new one in behind the hub.
Old Jul 12, 2007 | 02:39 PM
APEX CRX's Avatar
Default Re: Snapped stud replacement? (BILLETGRIP)
not enough room and don't listen to people who say otherwise
Old Jul 12, 2007 | 02:46 PM
BILLETGRIP's Avatar
Default Re: Snapped stud replacement? (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">not enough room and don't listen to people who say otherwise</TD></TR></TABLE>
ahhhhh ok i didnt know
Old Jul 12, 2007 | 02:51 PM
wiZCo's Avatar
Stouts 'n' Scotch
I thought the guy on 4thgenhatch replaced his by this method, but he had to cut the dust shield for the rotor....... I could be completely wrong though.
Old Jul 12, 2007 | 06:41 PM
gator88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">not enough room and don't listen to people who say otherwise</TD></TR></TABLE> Alright, I am glad i didnt remove it for nothing!! Yeah I couldnt see a way to get it out without removing it, im interested in the removing dust shield **** for when i have to eventually remove my hubs for something. Anyone care to elaborate, APEX CRX??
Old Jul 12, 2007 | 07:20 PM
tealjdmcrx's Avatar
here we go remove wheel and find a slide hammer. remove axle nut with an impact gun. it maybe a 32 or 34 mm , attach the slide hammer adapter to ur hub and secure the adapter tight . now pound away at the slide hammer until the hub comes off. Grab ur regular hammer remove the broken stud, insert the new stud into position and hammer it back in. next step is to center the hub back into its position and carefully tap it into the bearing. u should now be able to install the axle nut. again use the impact gun to tighten the nut which will pull the hub into position and ur done ,oh by the stake the axle nut
Old Jul 13, 2007 | 06:06 AM
CheeseCake's Avatar
Default Re: Snapped stud replacement? (tealjdmcrx)
thanks a lot! I thought I would have to remove the hub off the car complete, and use a shop press! I will be doing this tonight. Thanks guys!
simonEp3
Sep 3, 2008 04:49 PM
laocivic
Suspension & Brakes
Mar 26, 2008 01:52 PM
damn_import_culture
19
Apr 28, 2007 08:34 AM
NeWsCr
Dec 13, 2006 06:43 AM
JJ's civic
11
Oct 13, 2006 02:49 AM
