question about bleeding the coolant system
Old Jul 12, 2007 | 11:59 AM
efrex's Avatar
Default question about bleeding the coolant system
hey guys...i drive a 91 crx si with b16........when bleeding the coolant system,does the car need to be on? and how long do i bleed it for? and do i need to flush the radiator as well?..i wanna make sure i do this right..thanks in advance
Old Jul 12, 2007 | 12:12 PM
APEX CRX's Avatar
Default Re: question about bleeding the coolant system (efrex)
Yes car running, let it warm up, turn heat to hot on heater controls.
then open bleed valve slightly, you'll see coolant come out and if its bubbly then let it run until a steady stream of coolant comes out with no air in it.
Old Jul 19, 2007 | 07:49 PM
robertgg's Avatar
Old Jul 19, 2007 | 08:42 PM
powerpro_69's Avatar
Default Re: question about bleeding the coolant system (robertgg)
need to have the cap off too
Old Jul 22, 2007 | 12:16 PM
jpcrx's Avatar
where is the valve? im doing the same...
Old Jul 22, 2007 | 03:36 PM
robertgg's Avatar
Default Re: (jpcrx)
Old Jul 22, 2007 | 03:39 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robertgg &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Nice first couple'a posts there
The bleeder valve is located on the upper water neck (where your upper rad hose connects to the cyl head).
Old Jul 22, 2007 | 03:53 PM
janz3n's Avatar
Default Re: question about bleeding the coolant system (wiZCo)
you can also just jack the front of the car up and leave the rad cap off and wait for the fan to come on a couple times. you want to get the top of the rad the highest point of the collant system.
invisible
Mar 20, 2007 07:43 PM
importfanatic17
Jan 4, 2007 09:14 PM
draperj09
Oct 18, 2006 12:24 PM
DeDonDeRosa
Mar 21, 2006 10:37 AM
DelSlowdier
Jan 16, 2005 08:42 PM
