h22a revlimit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NNV »</TD></TR><TR><TD CLASS="quote">fail.</TD></TR></TABLE>
wtf fail.?? fail what you gutter ****?
Anything over the factory limit is starting to play with fire, but my stock H22 saw 8000+ repeatedly without catastophic failure.
Modified by A Blue Lude at 1:39 PM 7/12/2007
It should be fine, it's only a couple hundred rpms higher than stock revlimit. The only reason it's at 7800 rpms cause ur not makin anymore power beyond that, in fact u dont make any power beyond 7200 rpms if i remember correctly, so ur engine should be able to take it just fine, u'll just be losing all ur power if u rev it that high.
thanks so much you guys have been a great help
new problem i have a 96ek with a jdm h22a in it and im throwing the crank posit sensor?? wtf its an obd1 ecu and motor only thing obd2 on it would be the body
mine once survived around prob 10k rpm (misshift 3=>2 at 8k rpm
) but 8k wont do to much damage, but like already said, there's not use doing it unless you want to max your top speed with a little bit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">thanks so much you guys have been a great help
https://honda-tech.com/zerothread/2042043
hope that helps - apparently it's the distributor on obd2
</TD></TR></TABLE>https://honda-tech.com/zerothread/2042043
prelude2.2vtec
May 4, 2007 11:16 AM
crazi_E
12
Dec 2, 2004 04:42 PM
