auto ls, car starts, idles @ 2k then dies
Old Jul 12, 2007 | 10:51 AM
DookieHowser's Avatar
Default auto ls, car starts, idles @ 2k then dies
this happened to me twice already
i would start the car, the idle would jump to about 2k
the oil lamp would turn on, and the idle drops to 0 until it finally dies
afterwards, i would have to keep trying to start the car until finally it starts and is ok
oil level is still perfect and still looks clean
thanks in advance h/t
Old Jul 12, 2007 | 11:01 AM
JasonST's Avatar
Default Re: auto ls, car starts, idles @ 2k then dies (MasterPiece773)
If the oil light is on in ur car that's not good. Change the oil/filter, could be ur filter is clogged, or worse, ur oil pickup line's clogged. It's hard to say, but try to change ur filter first and oil. Try searching i'm sure u'll find lots good info in other ppl's threads too.
Old Jul 12, 2007 | 05:20 PM
B17lives's Avatar
sounds more like the oil light is a coincidence and the main relay is going out....its located under the driver's side dash above and behind the fuse box....might test that, its a single component with two seperate relays in it.
Old Jul 12, 2007 | 07:17 PM
awesome, i didnt think anything was wrong with the oil line
B17lives, have you encountered this problem before or heard of main relays going bad? is there anything else i should be looking out for?i just want to make sure that it is the problem, im going to check it tomorrow morning.
thanks for the responses
Balor_Gr
May 17, 2017 04:20 PM
rc1991
May 9, 2014 06:32 PM
rigles1
May 25, 2006 04:32 AM
HondaEJ7
Feb 13, 2006 05:18 PM
Poop111444
Aug 7, 2004 06:22 PM
