Those who have done DIY OEM foglight install I have a ?
Old Jul 12, 2007 | 10:42 AM
R Legend's Avatar
Default Those who have done DIY OEM foglight install I have a ?
Ok, so I finally decided to install my foglights that i've had for years, everything went smooth. Only question I had is the last step on the instructions it says to connect the 1 pin connector (assuming it is the power) to the 7 pin connector (same as turnsignals and regular lights) But is says if using an aftermarket alarm to connect it to the alarm connector switch. Anyone know where I could find this? I don't really want to be messing around with the alarm wiring.
Thanks,
Jerry
Old Jul 12, 2007 | 12:29 PM
nautica_t's Avatar
i don't think it should really matter whether you have an alarm or not when the connector is connected, but even thani didn't even connect mine there.
i connected that pin wire to the fuse box so i can have the fogs turned on whenever i wanted to. such as corners on fogs on, corners off fogs on. or whatever scenario you choose, but make sure you get the right one otherwise if you have it in the wrong spot, and you leave the switch on, you'll be running fogs on even when the car is off
good luck.
Old Jul 12, 2007 | 07:54 PM
94rs-turbo's Avatar
yeah my jdm fogs I wired them up so they turn on/off whenever the car has power
Old Jul 12, 2007 | 10:06 PM
R Legend's Avatar
well I just used the oem wiring which should be just plug and play, but where would I connect to turn on/off as wanted?
Old Jul 13, 2007 | 07:45 AM
94rs-turbo's Avatar
yeah I used the oem harness also the red wire that should go to the light switch put it in the fuse box there is a line of optn connections on top use a test light to see which one looses power when the car is off of test seach one
Old Jul 13, 2007 | 08:38 AM
R Legend's Avatar
Default Re: (94rs-turbo)
Old Jul 13, 2007 | 12:22 PM
nautica_t's Avatar
there you go. hehe. he said it better lol
JDMorgan
Dec 14, 2014 09:01 PM
Matgallis
Audio / Security / Video
Oct 1, 2003 05:13 PM
Ham'ed Hatch
Oct 3, 2002 06:09 AM
DRxCIVIC
Jul 3, 2002 06:45 AM
yellowbuffalo
Jan 1, 2002 11:12 PM
