Compression test results
I had borrowed my friend's compression gauge tester and these are the results I got
160psi on 1, 155psi on 2, 155psi on 3, and 135psi on 4
I'm not sure what the normal readings would be on a VX so I'm curious if there's an issue with the readings I got.
