93 integra turning wheel hop WEIRD!!!!!
Old Jul 12, 2007 | 09:34 AM
missionaryrider's Avatar
Default 93 integra turning wheel hop WEIRD!!!!!
hey i checked everything out seems fine, but when i turn hard going normal speed it starts to wobble like a thud thud thud thud really whick i dunno what it is anyone with same problem??
Old Jul 12, 2007 | 09:53 AM
MJobe's Avatar
Default Re: 93 integra turning wheel hop WEIRD!!!!! (missionaryrider)
check your tires for lumps or imperfections , i have had this before .
Luckly i cought it before it blew out.
Old Jul 12, 2007 | 10:49 AM
dizzzane's Avatar
Default Re: 93 integra turning wheel hop WEIRD!!!!! (MJobe)
make sure all your lugs are tight... sounds dumb but i've seen a dumb kid do it before and made the same noise... good luck
Old Jul 12, 2007 | 01:22 PM
bara6075's Avatar
Check if your axle Nut is tight, maybe the wheels are not balanced or need new tires
Old Jul 12, 2007 | 04:07 PM
teg_racer's Avatar
Default Re: 93 integra turning wheel hop WEIRD!!!!! (bara6075)
check your axles for grease. cv boot could be torn and dry or shot, mine did that i took it off and it fell apart
Old Jul 13, 2007 | 07:18 AM
dbb's Avatar
dbb
Mine started doing that on occasion as I would go over speed bumps. I think it's an early indicator that your one of your cv shafts is going out.
Old Jul 13, 2007 | 08:37 AM
turbo93da's Avatar
if not what was stated then i would look for the diff to be going out
they have the worse problem on left hand corning
Old Jul 14, 2007 | 09:24 PM
teg_racer's Avatar
Default Re: 93 integra turning wheel hop WEIRD!!!!! (turbo93da)
its a honda... you dont have an lsd lol one wheel gets more power than the other so one is bound to go out before the other. replace them both to save trouble down the road
Old Jul 17, 2007 | 04:02 AM
YEA I STILL DONT KNOW WHAT IT IS I REPLACED BOTH AXLES AND CHECKED EVEYTHING AND IT STILL IS DOING IT, AND ITS GETTING WORST . I CHECKED IF NETHING IS LOOSE BUT I DODNT SEE NETHING WRONG.
GRRR I CANT FIGURE IT OUT!
Old Jul 17, 2007 | 06:42 AM
AWD Terror's Avatar
rotate front tires to the back and back to front. May be a bad tire
teamhonda_johnb
Honda Civic (2001 - 2005)
Feb 18, 2009 10:13 AM
GodofRage
13
Jan 8, 2005 08:27 AM
civiccpedx
Oct 17, 2004 11:54 AM
fe519
May 18, 2003 03:44 PM
