integra knuckles on 99 civic hatch questions
Old Jul 12, 2007 | 09:20 AM
stuff215's Avatar
Default integra knuckles on 99 civic hatch questions
I did a search but didn't find the anwer I was looking for. Recently my my brakes started to pulse and my steering would shake tremndously when braking. I came to the conclusion to just change both front knuckles on my civic with DC knuckles.
So here is the question. Will there be an issue with cleareance since the integra rotors are bigger? Also will there be another issue with my rims feeting on the kncukles without problems? The rims are from the crx si their 14s? Sorry if my gammer is not as good as others.
Old Jul 12, 2007 | 09:35 AM
EL Vap133's Avatar
Default Re: integra knuckles on 99 civic hatch questions (stuff215)
The DC knuckles are basically the same knuckle than what you have now. Just use your stock upper arms.
As far as clearance, what rims do you have now? It can clear some 14" rims, but 15" rims are ok.
Old Jul 12, 2007 | 09:49 AM
stuff215's Avatar
Default Re: integra knuckles on 99 civic hatch questions (EL Vap133)
Thank you for your reply. So I shouldn't have any problems with the knuckles now. I was worried that the stock ef crx si rims wouldn't fit because of fitment issue with the integra knuckles. Thanks for your help man.
Old Jul 12, 2007 | 10:25 AM
BlueIntegraBoy's Avatar
I don't think the CRX rims will clear the caliper, maybe if it had a lower offset. I know the 90-93 Integra 14"s will clear.
Old Jul 12, 2007 | 11:31 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stuff215 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you for your reply. So I shouldn't have any problems with the knuckles now. I was worried that the stock ef crx si rims wouldn't fit because of fitment issue with the integra knuckles. Thanks for your help man.</TD></TR></TABLE>
No problem, it is a hit or miss on clearance. Good luck and you might want to look into some 15" rims, or some 14" stocks like Integra stock rims.
Old Jul 12, 2007 | 06:59 PM
stuff215's Avatar
Well I put the rims on after the knuckles were placed in. The rims did go in ok but fitment issue is still a problem. So I opted out to use some donuts for now until I get a set of new shoes for my car. Thanks for everyone help.
Slacker87
Mar 15, 2006 12:50 PM
95dxhatch
12
Feb 11, 2005 04:12 PM
cr-x si
Feb 23, 2003 10:40 AM
