engine turned bipolar
Old Jul 12, 2007 | 05:50 AM
Pussy_magnet_00's Avatar
Default engine turned bipolar *help*
2000 base prelude, slightly modified.
I used to shift at 7,300 around there perfectly with no problems than yesterday i install an amp and a bass and now my Vtech kicks in really weak and my engine wont let me rev any higher at 6,700, when it gets there it acts like if i just tuck the gas pedal off but i really didnt. I changed the spark plugs, checked wires and ran Duralube Fuel System Cleaner right after the problem started and nothing changed. Could the amp be taking too much voltage from the battery and all i need is a capacitor or could something more serious be going on?
Thanks
Old Jul 12, 2007 | 09:25 AM
piotrush's Avatar
Default Re: engine turned bipolar *help* (Pussy_magnet_00)
sounds like what used to happen to me when I was low on oil. Have you checkled it recently?
Old Jul 12, 2007 | 10:59 AM
NNV's Avatar
NNV
take that crap out of your car, no one wants to hear your music anyways, and it hurts your lude. Vtech is TELEFUCKINPHONES Vtec is AUTOFUCKINMOBILES
Old Jul 12, 2007 | 11:05 AM
nonvteclude's Avatar
Default Re: (NNV)
^^ ya you added nothing to help.
like piotrush said you are probably low on oil. or the screen on your vtec silinoid could be gunked up. the amp shouldnt be doing anything to the car.
Old Jul 12, 2007 | 11:18 AM
RaysBoomBoomLude's Avatar
Default Re: (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">^^ ya you added nothing to help.
like piotrush said you are probably low on oil. or the screen on your vtec silinoid could be gunked up. the amp shouldnt be doing anything to the car.</TD></TR></TABLE>
Ditto, Just coinicence about the amp install.
I installed a system as well recently, and had no issues.
Old Jul 12, 2007 | 04:00 PM
mattsnooz's Avatar
Default Re: (RaysBoomBoomLude)
most alternators pump out around 90 amps. I don't know what a typical car would use under regular driving conditions (I would like to know if anybody knows, I'm sure it fluctuates with speed, and accessories, ect.), but you should be able to run a heavy system without any problems.
Old Jul 12, 2007 | 04:23 PM
CHK4TIX's Avatar
Default Re: (mattsnooz)
I'm with everyone else that its not the system. I guess for ***** and giggles, you can check all your fuses, but Unless you somehow grounded something out and popped a fuse and now your in limp mode, I dont see how your system would be the problem.
I use to have a monster system in my first lude and the only thing it did ways make my car heavy as hell an my lights dim when the bass kicked in. But that was fixed when I put in a cap.
Old Jul 13, 2007 | 05:47 AM
Oil level is fine, i checked that either way without knowing it could be a problem. Sorry, brand new to honda, how do i clean out the screen? and Anybody who can point me in the direction of it?
Old Jul 13, 2007 | 05:52 AM
jdmh22a1's Avatar
be carful....and use a good parts cleaner....and let it dry....put it all back together...pretty straight....forward...i mean u know how to take it off....right....if u dont there should be 3 10mm bolts....unplug the wires that go the soleniod....and there u go...
Old Jul 13, 2007 | 06:03 AM
thanks but where is it?
Old Jul 13, 2007 | 07:06 AM
jdmh22a1's Avatar
Right behind the dizzy....distributor....it looks like this...
this is 1 off a b16...but this is the only close up of the vtec solenoid....
Old Jul 13, 2007 | 07:27 AM
thanks, took it out, cleaned it but there was no screen. I clean it out anyway. ill let u know if it worked.
thanks
Old Jul 13, 2007 | 07:55 AM
loudassVTEC's Avatar
Default Re: (Pussy_magnet_00)
It won't work. VTEC can't kick in weak. It's either on or off. It can't kick in partially, or half way. It's either all or none. If it is engaging, that's it. No need to clean anything. It may feel weak because the computer is in limp mode, and running very rich, with the timing retarded. In that case, what you're feeling is a power loss, and not VTEC kicking in weak.
Old Jul 13, 2007 | 09:15 AM
jdmh22a1's Avatar
???? No Screen....????
Old Jul 14, 2007 | 01:39 PM
Default Re: (jdmh22a1)
Maybe he just took off the top spool valve portion, and not the actual VTEC solenoid as a whole unit. I made that mistake when I was a noob at working on cars. The screen is behind the VTEC oil pressure switch, inside the gasket.
But like I said...its not going to help.
Old Jul 14, 2007 | 04:08 PM
i took off from the base, the 3 10mm screws and there is the gasket, no screen. Vtec started to kick in again but it still limits me to 6,800 rpm. I ran another diagnostic and i got error p1259 something about manufacturer moniter fuel...something like that, i wrote it down but i dont remember where i put it. a friend of mine told me he got the same error on his RSX and they had to change out the whole throttle body.
Old Jul 20, 2007 | 07:24 AM
found the problem seems that when i installed the sound system when i removed the kick plate on the floor where the ecu is the cables for vtec had become loose, put them back in and woooohoooo vtec relives :D
dtran002
Audio / Security / Video
May 10, 2017 01:26 PM
nnnggg
16
Jul 26, 2014 06:43 AM
sz9182
Nov 2, 2009 03:45 PM
civicmandx94
Mar 27, 2003 05:26 PM
sedantegrida
Jul 4, 2002 11:54 AM
