build up my h22a1 or just go jdm
Old Jul 12, 2007 | 05:12 AM
thao0094's Avatar
Default build up my h22a1 or just go jdm
i was thinking of going n/a on my 96 lude, but i have an h22a1 in it. i was going to get JUN camshaft kit, JUN super pistons, ceramic DC-S headers, skunk2 int. manifold, aem v2 CAI, skunk2 valves and greddy evo2 catback exhaust. should i just put those on my h22a1, or should i get a jdm h22a and put it on that?
Old Jul 12, 2007 | 05:19 AM
bluedlude's Avatar
Default Re: build up my h22a1 or just go jdm (thao0094)
if you are getting pistons, then there is no point in getting the JDM H22
Old Jul 13, 2007 | 10:08 PM
W4Rmachine's Avatar
Default Re: build up my h22a1 or just go jdm (bluedlude)
stick with what you got, sounds like a good plan. i wouldn't worry about "jdm" so much, the h22 w/ the JUN pistons/cams would be sick.
Old Jul 13, 2007 | 10:11 PM
98vtec's Avatar
moderator emeritus
if you have that amount of money, you have the money to get a better header.
what are you going to use to tune the engine?
Old Jul 14, 2007 | 12:17 PM
muggins's Avatar
Default Re: build up my h22a1 or just go jdm (98vtec)
i agree, you can get a better header than that...
Old Jul 14, 2007 | 04:13 PM
RaysBoomBoomLude's Avatar
Default Re: build up my h22a1 or just go jdm (muggins)
I only say get the JDM motor,
to build up, with out the car being down for a long time.
build it, then swap it.
Old Jul 14, 2007 | 06:53 PM
thao0094's Avatar
wat kind of headers would be better?
Old Jul 15, 2007 | 12:01 PM
h22a1_julien's Avatar
Default Re: build up my h22a1 or just go jdm (RaysBoomBoomLude)
JDM h22a obd1
USDM H22a1 obd1
Pretty much identical when it comes to specs..
Old Jul 15, 2007 | 12:04 PM
98vtec's Avatar
moderator emeritus
SSR, RMF, Hytech, SMSP and others.
Old Jul 15, 2007 | 01:12 PM
93sivtec's Avatar
Lots of headers are better that dc sports....search out the word header on the big red search button and you will see a ton of good h22 header threads w dynos and what not.
Old Jul 15, 2007 | 05:49 PM
Missing Gears's Avatar
Default Re: (93sivtec)
the jun stuff is overrated and overpriced. believe me i have used it in the past and there are better much cheaper options to go with.
dont waste your money on the jdm motor, dc header or the skunk valves and intake mani.
w/ the money you save you can sleeve the motor you already have, go w/ some weisco or cp 89mm pistons, good set of less expensive cams and valvetrain and that will make alot more power than your overpriced stock displacement jun piston setup even while keeping the stock intake and exhaust manifolds.
98cfprelude
Apr 9, 2012 01:12 AM
brandon_wright92
Feb 21, 2009 02:12 PM
EG6 Poe
May 21, 2008 11:54 AM
biggjimmy7
Nov 27, 2005 06:57 PM
JDMH22Prelude
May 4, 2005 09:27 AM
