motor mount question
I just bought a jdm b18b motor that was suppose to be an obd1 but they sent me an obd2 and some how my motor mounts don't fit. What kind of mounts can I use to make it work? Can I use mounts from other cars? I want to make it obd 1 but don't know where to start because it is being turbocharge so I will need to get it chip to run my 750cc fuel injectors. My friend said that all I need to change is the distibutor and get an obd 1 ecu is that all that I have to do or do I need to get more items? Some one that has done it before or anybody that knows please help. Is the head and block the same or different?
Thanks For Your Time
The stock integra upper tranny and drivers side mounts should work. I'm not sure about the rear. I know for the EK you need 99-00 si bracket. An obd-1 dizzy and obd-1 LS ecu is a must. As far as your turbo aspirations go, its a little more difficult than just getting a "chip" to control the 750cc injectors that you won't need on a stock motor. Do some research in FI. When you think you've done enough, spend another six months doing more.
Capt. Jimbo McSubipants
Mar 21, 2005 05:36 AM
jay.dee.em1
10
Feb 23, 2005 06:10 PM
