Air Conditioning install
Old Jul 11, 2007 | 10:27 PM
spikehairboy's Avatar
Default Air Conditioning install
Hey, I just got a 93 and i wanted to put AC in it. i know its a lot of work and a lot of money, but i have the skills and money to do it. Can someone point me out to a DIY link or something? I've tried searching but havent been able to come up with much.
Old Jul 12, 2007 | 03:08 PM
bump
Old Jul 19, 2007 | 11:38 AM
RedJdm95's Avatar
Default Re: (spikehairboy)
damn i want to know to.....well i know you have to intall a radator, fan, lines, and condenser, belt,and in your dash you have to change some black box for the ac also bump for some help!!!
Old Jul 21, 2007 | 01:22 PM
alright i did it. i bought a ac changeover kit from the local dismantler.
came with
lines
dryer
condensor w/ fan
ac compressor
evaporator
belt
relays for the fans.
installation is relatively straight forward.
its like a puzzle. look at all the lines put them in the right order on the ground and start installing the compressor tensioner belt dryer and on with the lines. on the inside you will need to remove the glove box (2 screws under the glovebox) then the reinforcment bar. then your car should have a little vent box u can see. take that out with 3 scews then you will have room for the evaporter box. install the evaportor box and make sure it sits flush to the firewall on the other side. install the grommit and the lines. vacuum your system tp 29.9 or as close to that as your can get in inhg. make sure u change the o rings too.
Old Jul 21, 2007 | 03:24 PM
555R's Avatar
93's are r-12. Unless you convert over to r-134a but I wouldnt if at all possible.
Old Jul 24, 2007 | 06:46 PM
95greenteg's Avatar
Default Re: Air Conditioning install (spikehairboy)
I posted a DIY step by step without pics here...It's on the second page...
https://honda-tech.com/zero...age=2
Old Jul 24, 2007 | 07:27 PM
wiZCo's Avatar
Stouts 'n' Scotch
It's for a 95, but should be the same:
http://www.hondaautomotivepart....html
BTW Majestic has all accessory install instructions from 95-up available online
solsi2000
Apr 8, 2008 08:44 PM
x_tuh_sy
Dec 11, 2007 05:08 AM
grey_ghost
Sep 21, 2007 09:53 PM
88crxb16a
Aug 15, 2005 08:00 AM
dingusjt
Nov 13, 2003 02:10 PM
