Need help with ZC swap in 89' Teg
Old Jul 11, 2007 | 08:14 PM
89ZCTeg's Avatar
Default Need help with ZC swap in 89' Teg
I am in the middle of my ZC swap and i have ran into a whole lot of issues. I am not really sure what car or year the ZC motor came out of. I was told a CRX Si. I need to know what all is required for this swap. It had a D16A1 motor in it. I have swapped out the ZC harness with the D16 harness due to the ZC harness having a lack of cam sensor and some various plugs were different. I swapped the D16 dizzy and cam sensor onto the ZC already. Now my issues are getting the drivers side motor mount on ,the d16 motor mount will only bolt up on 2 outta 3 holes, and finding a half shaft that fits. I used the stock D16 manual tranny on the ZC and the half shaft will only bolt up in 1 of the three bolt holes. What half shaft should i use and is there a motor mount that will bolt right up? or do you think that 2 bolts in the motor mount and one on the half shaft will be sufficient?
freddysEF
19
Jan 26, 2008 06:58 AM
89ZCTeg
Jul 13, 2007 11:23 AM
BuddhasGift2You
Nov 10, 2005 11:57 PM
turbozcteg
Nov 5, 2005 06:13 PM
BigDaddyRich
Sep 8, 2002 04:37 AM
