05 rsx type s headder
Old Jul 11, 2007 | 07:45 PM
chrisk20r's Avatar
Default 05 rsx type s headder
does a rsx jdm headder give u the same increase as a dc sport or any after market headder?
Old Jul 11, 2007 | 11:43 PM
Slo_RSX's Avatar
Default Re: 05 rsx type s headder (chrisk20r)
I am pretty sure the JDM and USDM header are the same on the 05-06.
Old Jul 12, 2007 | 12:29 AM
dc5RickK20's Avatar
Default Re: 05 rsx type s headder (Slo_RSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo_RSX &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure the JDM and USDM header are the same on the 05-06.</TD></TR></TABLE>
im pretty sure your wrong i have seen both headers and they are different the 05-06 header is pretty much the same as the 02-04 header
Old Jul 12, 2007 | 08:58 AM
bryce-o's Avatar
Default Re: 05 rsx type s headder (dc5RickK20)
that's correct, the usdm header for all years of the type s is a 4 into 1 design while the jdm itr header is a 4 into 2 into 1. you will probably see a few horsepower from upgrading, but it's probably not worth the hastle of buying the header and sway bar.
Old Jul 15, 2007 | 08:17 PM
chrisk20r's Avatar
thanks guys
Old Jul 15, 2007 | 08:30 PM
chrisk20r's Avatar
i just didnt want 2 waste 4 hundred bucks on 1 if it wasnt gonna give me the same power as an after market.
Old Jul 15, 2007 | 08:46 PM
Blah.'s Avatar
i heard if u change the block of a base model and put a type-s header do u gain more hp?
Old Jul 16, 2007 | 09:42 AM
mikestypes's Avatar
Default Re: 05 rsx type s headder (bryce-o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryce-o &raquo;</TD></TR><TR><TD CLASS="quote">that's correct, the usdm header for all years of the type s is a 4 into 1 design while the jdm itr header is a 4 into 2 into 1. you will probably see a few horsepower from upgrading, but it's probably not worth the hastle of buying the header and sway bar. </TD></TR></TABLE>
No, both are 4-2-1 headers. The USDM has a divider in it that keeps the 2 runners separate until after the bend in the double wall pipe attached to the cat.
It is definitely NOT worth the hassle going to a JDM header.
supwitu
Jun 4, 2010 05:20 AM
A3Elite
Jun 4, 2007 11:41 AM
taggart_lumpy
May 28, 2006 02:33 AM
96hondab16a
Mar 31, 2006 09:46 AM
ThinHoanG
Feb 28, 2005 12:28 AM
