Question about my Stock 92 Si
I'm having trouble with my fuel system. My fuel pump started to intermittently cut off, so assuming my fuel pump was the problem, I replaced my fuel pump. It started right up, so I thought I solved this problem.
Today, I went to go let it run for a bit.. and it seems I just wasted $100 on a fuel pump... as it was not working.
What else do I need to look at? Common issues?
The most common issue would be the main relay. I'd suggest pulling it and checking for any broken solder joints. There used to be a page on repairing them, but it's gone now. If you're handy with a soldering iron, you can fix it. Otherwise, get for for around $50 used.
But main relay is what my money's on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 »</TD></TR><TR><TD CLASS="quote">The most common issue would be the main relay. I'd suggest pulling it and checking for any broken solder joints. There used to be a page on repairing them, but it's gone now. If you're handy with a soldering iron, you can fix it. Otherwise, get for for around $50 used.
But main relay is what my money's on. </TD></TR></TABLE>
Cool, Thanks.. I'll check it out.
Something told me too look further before I spent 100 bucks on a fuel pump.. Oh well.
