gsr rear disc conversion on an ej8???sway bar???
Old Jul 11, 2007 | 05:33 PM
mach0's Avatar
Default gsr rear disc conversion on an ej8???sway bar???
alright i have a set of gsr rear disc goin on my ej8...can i stilluse the ctrrear sway orwould i have toget one from an itr???i have not doneit yet so i am curious
Old Jul 11, 2007 | 05:51 PM
philosofy1's Avatar
Default Re: gsr rear disc conversion on an ej8???sway bar??? (mach0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mach0 &raquo;</TD></TR><TR><TD CLASS="quote">alright i have a set of gsr rear disc goin on my ej8...can i stilluse the ctrrear sway orwould i have toget one from an itr???i have not doneit yet so i am curious</TD></TR></TABLE>
ctr sway bar? i'm lost.
if you already have a swaybar on there, then you can continue to use it. the same control arms that are on there you will use on the disc swap.
Old Jul 11, 2007 | 05:54 PM
JasonGhostz's Avatar
As long as you keep the LCAs to which your Sway Bar connects, you should be fine.
JasonGhostz
<FONT COLOR="white">NINJA</FONT>... I should've refreshed before posting... 2 votes for "No need for a new Sway Bar"
Old Jul 13, 2007 | 08:13 AM
mach0's Avatar
Default Re: gsr rear disc conversion on an ej8???sway bar??? (JasonGhostz)
THANKS
Old Jul 13, 2007 | 08:14 AM
mach0's Avatar
BY THE WAY THE REAR SWAY IS WAT I WAS GETTIN, JUST DID NOT WANT IT TO BE A WASTE IF I COULD NOT USE IT...THNX FOR THE RESPONSES
tsdenny
Sep 20, 2006 01:42 PM
triple
May 23, 2006 03:45 AM
SE7EN3S
14
Aug 23, 2004 01:02 PM
tzonni
Oct 11, 2003 04:00 PM
