Jumping Tach Needle
Old Jul 11, 2007 | 05:33 PM
Smash03's Avatar
Default Jumping Tach Needle
I drive a 90 LS and the needle in the tach keeps fluctuating. My car runs fine and there's no messed up idling. The needle goes to it's normal position (meaning which ever rpm it should be at) when I step on the gas hard. But when I go easy on the pedal, it begins to jump around again. Can somebody help me out here?
Old Jul 11, 2007 | 05:51 PM
Integra21's Avatar
Default Re: Jumping Tach Needle (Smash03)
prob distributor, but you could try just replacing the ignitor.
try/check wires and plugs also.
Old Jul 11, 2007 | 08:02 PM
Sumslapper's Avatar
Year 3030
Default Re: Jumping Tach Needle (Integra21)
dizzy
Old Jul 11, 2007 | 08:13 PM
Spoon ITR's Avatar
Default Re: Jumping Tach Needle (Sumslapper)
deff the dizzy
i had this problem a month or two ago
replaced the dizzy and no more problems
Old Jul 12, 2007 | 12:37 PM
Smash03's Avatar
Default Re: Jumping Tach Needle (Spoon ITR)
Hmmm...I just replaced my dizzy a couple of months ago. Is there anything else that could keep causing my dizzy to go bad?
Old Jul 12, 2007 | 01:26 PM
JasonST's Avatar
Probly Loose ground or tach's starting to go bad... Check all ur grounds, especially the ecu ground.
Turbo_TONY
Mar 21, 2007 08:46 PM
e-Roc
Jul 3, 2006 02:55 PM
force-fed
May 9, 2006 05:05 PM
legendboy
Jun 24, 2005 10:03 AM
raceboy71
Sep 3, 2002 02:33 PM
