B16a hasport Shift Linkage??
Old Jun 8, 2002 | 12:38 PM
90_Civic_Hatch's Avatar
Default B16a hasport Shift Linkage??
I am currently putting in my B16a innto my 90 Civic DX HB. I came across a problem with the bushing (where it connects to the tranny). Hasports did not come with one and my old one doesnt fit. Which bushing am I supposed to use? Probly an integra? What yaer?
Thanks
Old Jun 8, 2002 | 01:31 PM
SuperCivic's Avatar
Default Re: B16a hasport Shift Linkage?? (90_Civic_Hatch)
order some energy suspension shifter bushings for a 90-91 integra. http://www.summit.com has em for about 15 bucks
Old Jun 8, 2002 | 02:01 PM
Default Re: B16a hasport Shift Linkage?? (SuperCivic)
Thanks alot
Old Jun 8, 2002 | 05:42 PM
E-AT_me's Avatar
any bushing from any B-series tranny will work. integra, del sol, anything. but don't get the poly's, that bushing is soft for a reason. heheee. plus, you'll need 2 metal plates to go with them. about 25 bucks at the acura or honda dealer.
Old Jun 8, 2002 | 05:44 PM
Urban Business
Guest
Posts: n/a
Default Re: B16a hasport Shift Linkage?? (Rexman)
ha i wont tell you whos car has this but heres how we got around that:
took the stock d16a6 bushing and wrapped electrical tape around it to increase the size. smashed it into place w/ a hammer
Old Jun 8, 2002 | 08:25 PM
Default Re: B16a hasport Shift Linkage?? (TorteX)
I was about to do the same thing almost. I had some radiater hose I was going to use. Surprisingly it fits nicely into the ring of the linkage but i still need a bolt or something to bolt into the tranny (RIGHT???)
Old Jun 8, 2002 | 09:29 PM
keebler65's Avatar
i just got to that stage today in my swap. my motor came with the JDM linkage so i just used the bushing in that and put it into the hasport linkage. then i used a large washer and it seems fine
Old Jun 8, 2002 | 10:00 PM
B16ED4G's Avatar
I had the same problem when I got my swap. So I ordered the bushing, 2 washers and the bolt from acura, total cost about $23. Then later when I bought my ENERGY SUSPENSION bushing kit, I replaced it with the poly one. Tell them at the dealer you want to see a picture of the shift linkage setup for a 95 integra. you can just pick the parts you will need, thats what I did.
Chris
Old Jun 8, 2002 | 10:55 PM
flat-blk-HB's Avatar
Default Re: B16a hasport Shift Linkage?? (B16ED4G)
Just a little note on the washer deal....
I know this is GHETTO but it will work and possibly help someone someday. You can use the end of a Coca-Cola can the bottom and punch a hole in it and there you go you have a "perfect" size washer. I have had atleast 2 friends who have had to do this on there cars. It works great Hell they used them for like 2-4 months before they even got the right washer. So I just thought I would let you guys in on that lil piece of INFO. hahahaha
Old Jun 8, 2002 | 11:26 PM
Default Re: B16a hasport Shift Linkage?? (ED6)
Thanks for all the info guys. That definately helps out.
gallarr
Transmission & Drivetrain
May 30, 2015 10:11 PM
sbcrx
Jun 17, 2004 09:24 PM
Driven
Nov 11, 2003 03:06 PM
NikoZai
Jul 23, 2002 04:53 PM
zilbotd
Sep 6, 2001 11:09 PM
