Engine stalls and shacks when idle with ac on
Old Jul 11, 2007 | 10:03 AM
crazyguy's Avatar
Default Engine stalls and shacks when idle with ac on
as title says..
it is a eg civic.and the rpm is around 600 when idel
any idea ??
Old Jul 11, 2007 | 01:36 PM
crazyguy's Avatar
Default Re: Engine stalls and shacks when idle with ac on (crazyguy)
ttt
Old Jul 11, 2007 | 01:57 PM
dhatb0ijohnny's Avatar
my car shakes while idling with ac on also..
up for info
Old Jul 11, 2007 | 02:15 PM
slowcivic2k's Avatar
Default Re: Engine stalls and shacks when idle with ac on (dhatb0ijohnny)
Your car should boost its idle speed by 100-150RPM when the compressor is on, if it does not do this, you may have an idle control issue. Check PCV system for functionality and the IACV as well.
Tip: The engine should idle at 450RPM or so with the IACV unplugged, if it dies, Your PCV is restricted.
Old Jul 12, 2007 | 07:15 AM
crazyguy's Avatar
Default Re: Engine stalls and shacks when idle with ac on (slowcivic2k)
thank u .i will check it today
Bhi Rds
May 8, 2016 06:19 PM
georgiajdm
Apr 6, 2010 04:44 PM
an2ny888
Aug 4, 2004 04:33 PM
vietboixstunnah
Aug 7, 2003 12:41 PM
