Can a clogged catalytic cause cel #1
Old Jul 11, 2007 | 05:18 AM
.Hookedonhatch.'s Avatar
Default Can a clogged catalytic cause cel #1
I have been reading up on here after searching. I just put a brand new engine harness in the other day complete stock and unmolested. I added a brand new honda factory o2 sensor and my car has been running awesome. Today coming home about 15 mins into my trip my car threw cel #1. The wiring is stock and the o2 is brand new and plugged in securely. My cat looks old as ***** and when this happended i could smell like a metal/ egg type of smell coming up from underneath. My question is could a clogged cat cause a brand new o2 to throw a code? The car is an EG hatch with a poor mans swap. Thanks
Old Jul 11, 2007 | 05:22 AM
Probot's Avatar
Default Re: Can a clogged catalytic cause cel #1 (.Hookedonhatch.)
absolutely can...it can cause the o2 sensor to go bad and if the CAT is clogged it can cause a dramatic loss of power as well cause a head gasket to blow (worse case scenario)...just buy a new o2 sensor (assuming you ARE talking about the one that goes into the CAT) and get a stock replacement CAT...night and day difference
Old Jul 11, 2007 | 05:35 AM
pdiggitydogg's Avatar
primary o2 is pre-cat...so i dont see how it could
Old Jul 11, 2007 | 05:37 AM
Probot's Avatar
Default Re: (pdiggitydogg)
well he didnt really specify..just said he put new o2 sensor
Old Jul 11, 2007 | 05:38 AM
cel 1 is primary o2
Old Jul 11, 2007 | 05:48 AM
Probot's Avatar
my bad sir....not quite familiar with the CEL codes..i just know from experience that my rear o2 sensor went bad cause of my CAT
Old Jul 11, 2007 | 05:49 AM
yes cel is primary o2, i am not a running a secondary and as to the best of my knowledge obd1 doesnt require a secondary o2. The question i have though is could a clogged or fryed cat cause a brand new factory o2 sensor to throw a cel like that, i have been told it has and im gonna replace the cat regardless i just wanted to if anyone has experienced this before or is that even a mechanical possibility. Thanks
Old Jul 11, 2007 | 10:54 AM
Default Re: (.Hookedonhatch.)
anyone else any ideas???
sickofitall1113
Jun 11, 2007 10:20 AM
JMatos
Oct 17, 2006 09:34 PM
DFW
Sep 20, 2006 11:01 AM
joshcivic00
Nov 18, 2005 07:14 AM
sfgiants11
Jun 5, 2005 07:22 AM
