24.5x8x13.... what do you guys do for front suspension
Old Jul 11, 2007 | 05:18 AM
Topdawgg's Avatar
Default 24.5x8x13.... what do you guys do for front suspension
Should I pick up some coilovers, or put on the stock springs/struts?
Im really not sure about fitment...
How is breaking with the 24.5's, rub the fenders at all?
post some pics of your car running this size slicks..
Ive got an EG, so that would be most helpful...
thanks
Old Jul 11, 2007 | 06:31 AM
BoostedJeff's Avatar
Default Re: 24.5x8x13.... what do you guys do for front suspension (Topdawgg)
Just pick up a set of Omnipower Coilovers, There will be times when you want to raise you car... since Im sure this is a street car.
Old Jul 11, 2007 | 06:38 AM
Topdawgg's Avatar
Default Re: 24.5x8x13.... what do you guys do for front suspension (BoostedJeff)
well, im happy with the suspension I have on it now, I just dont know if i can run these slicks with it
Old Jul 11, 2007 | 07:26 AM
Fitti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">well, im happy with the suspension I have on it now, I just dont know if i can run these slicks with it</TD></TR></TABLE>
Well what suspension do you have on there right now? That would help a little
Old Jul 11, 2007 | 08:17 AM
Topdawgg's Avatar
Tein S-techs and Tokico Blues
Old Jul 11, 2007 | 08:20 AM
BolivianFuego's Avatar
Default Re: (Topdawgg)
I dont think that would work too well, you need to raise it up to stock height or else your in trouble.
Old Jul 11, 2007 | 11:57 AM
clockedout's Avatar
Default Re: (BolivianFuego)
I think you ought to get some coilovers in there at the minimum. Not a pretty site once that fender takes a bite out of the slicks.
Definitely raise the car somehow.
Old Jul 11, 2007 | 12:03 PM
Default Re: (clockedout)
Yep, Screw up your slicks!
Old Jul 11, 2007 | 12:06 PM
cptengineer's Avatar
we use 3 inch stroke KING shocks with eibach springs, forgot what rate.
oh and lamb struts in the rear
Modified by cptengineer at 4:03 PM 7/11/2007
Old Jul 11, 2007 | 01:31 PM
Topdawgg's Avatar
ok heres a question... would stock suspension be ok in the front?
its the back that squats... correct?
Old Jul 11, 2007 | 01:52 PM
h22crxpwr's Avatar
Ebay coilovers w/ 1000lb drag springs in the rear. cheap and it works!!
Old Jul 11, 2007 | 03:05 PM
92redhatch's Avatar
i was wondering the same thing. can i run the 24.5 in slicks with h and r springs and type r shocks?
right now im running a 24.12in tire on the street and it does not rub unless i take a sharp turn or hit a bump.
Im gonna try a 24.5in slick. i dont think its going to rub down the track or when i brake.
Old Jul 11, 2007 | 06:05 PM
Boostfed's Avatar
New User
Default Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering the same thing. can i run the 24.5 in slicks with h and r springs and type r shocks?
Im gonna try a 24.5in slick. i dont think its going to rub down the track or when i brake.</TD></TR></TABLE>
You do realize the slicks are wider and also wider wen you air them down? Also the slicks grow in size when you heat them up in the burn out box For 24.5" slicks I think you need coilovers up front ot just be high enough to clear it. I have ripped a couple of bumpers off before, ben doing well with Tzus fasteners up front and raised up much mroe now also
Old Jul 11, 2007 | 06:32 PM
DraginX's Avatar
Default Re: (Boostfed.com)
Ryan, you'll need coilovers up front for sure. I wish you could have seen my slick from the PEI races, with those dips at the end of the track with the tires about 1 1/2" below the fenders it dropped down enough to grab one of the inner fender tabs, pull it out and then sliced the slick all the way around. Thank god it didn't blow it out but it ruined a brand new slick no the less... Order a cheapy set of coilover at the very least...
Old Jul 11, 2007 | 06:38 PM
92redhatch's Avatar
thanx for the info. i just think it sux that i have to re align and fix the camber on my car after i change the suspension set up. i was hoping the get it to work but i guess i might have the run 23in slicks.
Old Jul 11, 2007 | 06:51 PM
Topdawgg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DraginX &raquo;</TD></TR><TR><TD CLASS="quote">Ryan, you'll need coilovers up front for sure. I wish you could have seen my slick from the PEI races, with those dips at the end of the track with the tires about 1 1/2" below the fenders it dropped down enough to grab one of the inner fender tabs, pull it out and then sliced the slick all the way around. Thank god it didn't blow it out but it ruined a brand new slick no the less... Order a cheapy set of coilover at the very least...</TD></TR></TABLE>
yea, im gonna see what i can get for a cheap coilover for the front, the rears are ok?
Old Jul 11, 2007 | 07:55 PM
DraginX's Avatar
It would be nice to have a good strong set in the rear, but last year I just ran a set of race spec springs in the back and coilovers in the front. It wasn't the best setup but I managed a 11.4 pass with it with full street trim. But if you don't have the extra cash or time, I would at the very least get some coilovers for the front and then get a good setup for next season.
Old Jul 12, 2007 | 07:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
got a progress drag setup last year, thinking omni now, but imma live with it for now.
Old Jul 13, 2007 | 11:46 AM
k24killer's Avatar
Default Re: 24.5x8x13.... what do you guys do for front suspension (boostedcivicsir)
ryan watch ebay for omnipower i bought mine on there cheap and there has been a few more sets since then they work.
Old Jul 14, 2007 | 09:40 AM
juda7's Avatar
Function(F2) Coilovers all around. No Rubbing. 450lb Front, 800lb Rear.
square_1
Oct 9, 2007 11:56 PM
Mushvroom
Suspension & Brakes
Oct 23, 2005 06:59 PM
sleeperLS
Aug 25, 2005 09:20 AM
SPOON DC2
Aug 17, 2004 12:24 PM
