B20/Vtec
Old Jul 11, 2007 | 04:19 AM
darkintegra's Avatar
Default B20/Vtec
Has anyone built a stock bottom B20/vtec with a B16 head and ITR cams and had any problems?I heard that if you run any cam other than a gsr you mess up the pistons. Is it true?What do I have to do so that doesnt happen?
Old Jul 11, 2007 | 08:39 AM
2redstars's Avatar
didnt like the last thread?
anyway, i had a turbo b20/b16 w/gsr cams, reved to 8200, with no problems(until it cracked a sleeve of course). im sure someone has the answer your looking for, just give it a little time.
Old Jul 12, 2007 | 06:20 PM
GS-R Del Sol's Avatar
Default Re: (2redstars)
Why would you want to leave the bottom end stock, B20's got low cr, you don't want or need more aggressive cam than gs-r with cr so low. I am building a B20Z vtec, putting some 11.5 cr pistons, rods, (make sure you use arp rod bolts if you want it to last), gs-r head with full skunk2 valve train, should be making some nice power, I suggest you raise that compression
Old Jul 12, 2007 | 06:59 PM
choreboy's Avatar
The reason why you shouldnt use cams any bigger than gsr is because the stock pistons on a b20 dont have enough valve relief .
Old Jul 12, 2007 | 09:17 PM
b20powereDA's Avatar
Default Re: (choreboy)
i beg to differ. im running the exact setup u stated before. stock b20 block, itr cams/valvetrain, aebs mani, 70 mm tb, mildly ported head, etc. and ive got probably about 20,000 miles on this motor with no problems
Old Jul 13, 2007 | 08:15 AM
Default Re: (b20powereDA)
Im putting my B20/vtec in a DA also.How do you like yours?What are the track times?
Old Jul 13, 2007 | 08:17 AM
Default Re: (darkintegra)
i like it. no track times yet. the only track we have around here is an 1/8 mile track and its a shitty track and its about an hour away
Old Jul 14, 2007 | 06:20 AM
cmasonrun's Avatar
i have a b20vtec with JE pistons, eagle rods and built head, compression is like 12.8, im running skunk2 stage 2 stuff in the head and it put 216 hp to wheels and 155 tq..... not sure on the track times, ill prolly find out on tuesday or wensday, tranny is being rebuilt as we speak....
del_orson
May 24, 2007 02:50 AM
luda-tec
May 9, 2007 03:00 PM
xMilitantEGx
Feb 18, 2004 01:25 AM
rev-speed
Feb 11, 2004 09:51 PM
SICKSOLSI
Sep 26, 2003 08:36 PM
