lower balljoint
okay on 90-97 i don't see why there isn't a tutorial for this.. but anyhow... i don't get a few things.. do i need to take off the whole knuckle or just axle/tierod/
okay how do i exactly take off the lowerballjoitn from knuckle. we got the c-clip out and everything.. hammer it in.. hit the studs.. the jooint flexes 2 much... even tried hitting the the knuckle.. i know its not taper fit.. so whats the best way removing the joint out of the knuckle.. don't say take it to machine shop or use a press.. what if theres none around.. i want to learn...
also how do u get it to sit right in.. nice and tight without pressing it.. do u hit the top of the joint until it sits firmly into knuckle.. plrease help.. i want alot of opinions..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">you should be able to use the ball joint press to press it out as well if it comes with the right attachments.</TD></TR></TABLE>
yeah i forget waht reason but, i think it was somethign to do with the attachment ring i had it wouldnt clear properly or something for me to press it out, hence why i broke out the hammer
use a socket and put it over the bolt that sticks out and hit the socket instead of the balljoint bolt. and like everyone else said rent a balljoint press it will make things alot easier.
a rubber mallet wont work. i tried that and got just about nowhere. if you cant get a hold of one you got to be creative and make your own tool. what i did was got a steering wheel puller triangle piece and stuck 2 long bolts through it and then put sockets over it and tightened the sockets down with 2 nuts and i had a little fork thing. so then i got a c-clamp and put my fork contraption thing on one end and the flat end on another that way i could press the balljoint in. a 2inch socket would probably work to with a c-clamp.
if you can't get the ball joint press tool you could try using sockets and a vice if the vice will open far enough to fit everything between the jaws.
LaterApex
Suspension & Brakes
Oct 21, 2005 09:33 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
