ITR Cluster in EG CX Hatch
Old Jul 10, 2007 | 06:42 PM
NwAmH's Avatar
Default ITR Cluster in EG CX Hatch
i need insight on whether or not this pinout will work on a 2000 usdm itr cluster into a 1994 cx hatch. i noticed how sum tried the swap on honda-acura but it wasnt a clean install, and someone on here did the same but his archived photos were lost. From what the post read he actually made the fitting of a integra cluster look better with minor adjustments. Bottom line is i need a recent or most accurate pinout and i want to know does anything comes closer to this pinout and does anyone have a better diy fit for the cluster swap.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Jul 10, 2007 | 06:58 PM
B18bEG6ick's Avatar
Default Re: ITR Cluster in EG CX Hatch (NwAmH)
the pictures on his site is down or it's not working, but the pins are on the bottom and some of the pictures work.
http://jdmlyfestyle.com/integr...g.htm
good luck
Old Jul 10, 2007 | 07:05 PM
NwAmH's Avatar
i have that link and i saw his results as far as fitting and it wasnt the best, but i have it as a worst case senerio, i'll just grab the dremel and see if i can make it work better
Old Jul 10, 2007 | 08:00 PM
NwAmH's Avatar
bump
Old Jul 11, 2007 | 10:17 AM
BlueIntegraBoy's Avatar
https://honda-tech.com/zerothread?id=1053318
Old Jul 11, 2007 | 10:27 AM
speedooo's Avatar
Default Re: ITR Cluster in EG CX Hatch (BlueIntegraBoy)
theres 2 or 3 write ups on this somwhere
lsismore
Jan 13, 2006 01:14 AM
9sihatch3
Sep 22, 2005 08:18 PM
a1320honda
Apr 7, 2004 11:48 AM
eric.
Oct 17, 2002 04:30 PM
DB8
Jun 10, 2002 07:53 PM
