Changing Odometer reading?
Old Jul 10, 2007 | 06:14 PM
vtecftw's Avatar
Default Changing Odometer reading?
Alright im uninstalling my CTR cluster and its forsale(msg me if interested) and i would like to change my factory cluster so it will have the original reading that the car has had on it. Is there a DIY to do this? i know This is a controversial issue but i am adding to my old cluster so it is acurate with the car.
Thanks in advance
Old Jul 10, 2007 | 06:48 PM
vtecftw's Avatar
UP^
https://honda-tech.com/zerothread?id=837111
I found this link but the pictures are dead
anyone?
Old Jul 10, 2007 | 07:03 PM
vtecftw's Avatar
Found something good enough guys
http://www.team-integra.net/fo...08087
Old Jul 11, 2007 | 10:19 AM
BlueIntegraBoy's Avatar
Default Re: Changing Odometer reading? (vtecftw)
Uhh, you can roll back the odometer on a Civic cluster without removing the needle and gauge face.
Old Jul 11, 2007 | 10:27 AM
speedooo's Avatar
Default Re: Changing Odometer reading? (BlueIntegraBoy)
i took the speedo out of cluster i had lyin around and started playing with the trip odometer, which is easier to get to than the total odo. i found that if u roll back the trip odo the total rolls back with it.
Old Jul 11, 2007 | 10:32 AM
Default Re: Changing Odometer reading? (speedooo)
Well, the Canadian odos are on the bottom of the speedos, unlike the USDM speedos. All you need to do is take a small flathead and pry the metal bar at the bottom of the speedo from one side. This will allow the odo numbers to free spin. Match the mileage and line up all the numbers (and gears) straight, then push back the metal bar.
DaFredsta
Oct 18, 2009 01:31 AM
GSRBrent
Nov 30, 2007 07:09 PM
