can you use the stock 95' dx wiring harness+ecu for b18b swap?
I haven't really dealt with non-vtec stuff. I was just wondering if I could use the stock 95' dx engine harness and ecu for an obd1 b18b swap? also, can you chip a 95' dx ecu?
cool, thats what I thought. I was going to run a chipped non-vtec ecu. I have crome pro so I can tune it. will the harness fit fine, I did some searching and someone said something about lengthing some plugs.
when I did my b16a swap I just seperated the O2 wires from the main harness and re routed them so I didn't have to splice them. I think rewyre or something like that sells extensions or if it is a USDM swap you can use the harness that comes with the motor. it will plug right in a the shock tower.
gl
gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">yes, you can use the stock wiring harness, the dx ecu will run it, but would get an LS ecu or have yours chipped to LS specs</TD></TR></TABLE>
x2
x2
Arthas
27
Aug 17, 2010 08:42 PM
