OBD2b to OBD1
Old Jul 10, 2007 | 05:48 PM
EJ8 Kenobi's Avatar
Default OBD2b to OBD1
I searched but because I don't know a lot about this topic I'm not sure what I'm looking for. I need to eliminate the o2 sensor on the cat. I have a 00' civic, d16y8 with stock P2P ecu. I know it's going to throw a code with the cat o2 sensor gone. I can I get a P28 ecu with a obd1 conversion harness and still have the car run up to par? Or will the conversion harness work with my P2P ecu?
Old Jul 10, 2007 | 06:25 PM
builthatch's Avatar
MiG-21 superfan
Default Re: OBD2b to OBD1 (EJ8 Kenobi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi &raquo;</TD></TR><TR><TD CLASS="quote">I searched but because I don't know a lot about this topic I'm not sure what I'm looking for. I need to eliminate the o2 sensor on the cat. I have a 00' civic, d16y8 with stock P2P ecu. I know it's going to throw a code with the cat o2 sensor gone. I can I get a P28 ecu with a obd1 conversion harness and still have the car run up to par? Or will the conversion harness work with my P2P ecu?</TD></TR></TABLE>
obd1 p28 will work just fine if you get a jumper harness to convert. i suggest boomslang fabrication.
you can run the obd2 ecu and a test pipe with the secondary 02 in place if you do the o2 spark plugs non-fouler trick http://forums.evolutionm.net/s...15795
Old Jul 10, 2007 | 08:15 PM
EJ8 Kenobi's Avatar
Default Re: OBD2b to OBD1 (builthatch)
Well that's my problem. The high flow cat I bought o2 holes do not line up correctly and I cannot use the o2 because it's too long. So the non fouler trick would make my problem worse. So rather than going through the hassle of getting a new cat I thought I would just eliminate the o2 sensor all together. Eventually I want to run hondata so I would be changing my ecu in the future anyway.
Old Jul 10, 2007 | 08:17 PM
builthatch's Avatar
MiG-21 superfan
hmm, what do you mean the 02 is too long&gt; the wires?
Old Jul 10, 2007 | 09:40 PM
EJ8 Kenobi's Avatar
I'll take a picture tomorrow when it's light out and show you what I mean.
lexrob
Feb 22, 2010 02:55 PM
gray_civic_coupe
Nov 4, 2005 02:20 PM
1991hondahead
May 7, 2004 03:29 PM
civicshowracing65
Mar 9, 2004 11:33 AM
