P28 and P72...is there a difference?
Old Jul 10, 2007 | 03:00 PM
JKov240's Avatar
Default P28 and P72...is there a difference?
I'm currently running a "chipped" P28 ECU (it was done half-*** to say the least)...it's chipped for no knock sensor and no rev limiter, but my main problem with this ECU is that I can't scan it for codes and data streams (everytime I plug in it freezes the scanner).
I've been looking around since I'm new to this whole "chipping" thing and I know that my P28 is used in SOHC VTEC Civics, but is there really a difference between the P28 from SOHC VTEC Civics and the P72 used in GS-R's?
Old Jul 10, 2007 | 07:33 PM
egsleepercivic's Avatar
P72 has IAB control and Knock sensor board, p28 does not
Old Jul 11, 2007 | 04:36 AM
JKov240's Avatar
Default Re: (egsleepercivic)
That cleared a few things up
Thanks
Old Jul 17, 2007 | 07:43 PM
b18c1ej8's Avatar
Default Re: P28 and P72...is there a difference? (JKov240)
correct me if im wrong but supposedley jdm ecu's have a bit of a problem being read. i have a jdm p72 and the local shop couldnt read it due to the fact it was a jdm ecu
Old Jul 18, 2007 | 03:12 AM
I think you can't scan obd2 jdm ecu's with a scan tool, i'm not sure
Modified by egsleepercivic at 10:37 AM 7/18/2007
Old Jul 18, 2007 | 06:42 AM
Relic1's Avatar
are you talking OBD1 or OBD2? (there are P28s and P72s in both)
JDM OBD2 ECUs are not scanable by the conventional OBD2 scan tool.
OBD2 ECUs are also more rare to chip, so I have a feeling you're talking OBD1.
OBD1 ECUs are easily chipped, but scan tools for them are more rare and the standard OBD2 versions do not work.
Once chipped you are running code from what ever program you are running, if I remember correctly most of the programs out there run off a JDM base, so no communication protocols.
Datalogging is your best bet there.
eg6sittingon57cs
Mar 12, 2008 10:46 AM
team 15
Jan 11, 2007 05:59 AM
L_K
Aug 21, 2006 06:59 PM
StinkyTofu
Feb 4, 2003 08:54 PM
IdotheSHOCKER
May 30, 2002 12:31 AM
