Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine?
Old Jul 10, 2007 | 02:19 PM
818blue818's Avatar
Default Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine?
i have an 89 honda civic dx hatch.
i have a 96 single cam vtec in it now,
but i want to get the zc dohc,
and i was wondering if i could use the wire harness from an 89 civic dx and the computer as well please let me know thanks.
*****************FOR SALE*********************
THIS IS IS CURRENTLY IN MY 89 HONDA CIVIC DX.
ITS A D16 SINGLE CAM VTEC.
THIS MOTOR HAS AN UNKNOWN MILEAGE.
THE REASON Y IM SELLING IT IS BECAUSE I WANT TO UPGRADE TO A ZC.
I RECENTLY TOOK IT TO THE MECHANIC AND CHAGED THE CAM SEAL, CRANK SEAL, TIMING BELT, WATER PUMP, SPARK PLUGS, SPARK PLUG WIRES, DISTRIBUTOR CAP, THE IGNITION ROTOR INSIDE THE CAP, AND THERMOSTAT. THE OIL CHANGE HAS BEEN DONE RECENTLY AS WELL.I HAVE RECEIPTS IF YOU WOULD LIKE TO SEE. ENGINE IS IN REALLY GOOD SHAPE. IT ALSO NEEDS A TPS (THROTTLE BODY) SENSOR. AND I BELIEVE LIKE 1 MORE SENSOR. OTHER THAN THAT EVRYTHING IS FINE. IVE SPENT ABOUT $265 IN PARTS AND LABOR. PLEASE FEEL FREE TO EMAIL ME ANY QUESTIONS OR CONCERNS. I WILL THROW IN THE WIRE HARNESS AS WELL. I HONESTLY DONT KNOW THE CONDITION OF THE HARNESS . IM OPEN TO TRADE FOR A BODY KIT, OR JUST CASH NO SHIPPING. PICK UP ONLY. IF INTERESTED LET ME KNOW AND I WILL TRY TO GET PICTURES TO YOU AS SOON AS I CAN.
Old Jul 10, 2007 | 02:22 PM
Donkey85's Avatar
Default Re: Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine? (818blue818)
you will still have to wire it for mpfi which is running two extra wires to the ecu
Old Jul 10, 2007 | 03:52 PM
818blue818's Avatar
could you please explain its cuz i dont know and im trying to learn thanks
Old Jul 10, 2007 | 04:05 PM
Donkey85's Avatar
well wait, now that i re read ur post u say that you have a sohc vtec in it running currently? that is already a mpfi motor so if that motor was running in ur car then yes use that harness and you wont have to do any wiring
Old Jul 10, 2007 | 04:10 PM
janz3n's Avatar
Default Re: Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine? (Donkey85)
use the button called search at the top right hand corner of your screen. its in red. or check out the faq forum.
Old Jul 10, 2007 | 04:21 PM
White91EF's Avatar
Default Re: Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine? (janz3n)
you'll need a pg7 88-89 integra ecu or jdm pm7 ecu for the ZC... you can also use the pm6 but it wont be as fast.
Old Jul 10, 2007 | 04:25 PM
818blue818's Avatar
so which one would you say is best? but wont harm the car that much? so what i understand so far is that i could use the 89 hatch wireharness for the zc engine but could i use the 89 hatch computer if not what should i use? thanks for everyones help
Old Jul 10, 2007 | 04:47 PM
90Zcrx's Avatar
PM7 is optimum, then I'd say PM6 then PG7. Those PG7 ecus are kinda *** IMO, you can't chip them easily and I've had two just crap out on me, versus no PM6's crapping you. Alternatively, you CAN run an obd0 PR4, but it'll run a bit rich.
Old Jul 10, 2007 | 04:56 PM
818blue818's Avatar
Default Re: Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine? (90Zcrx)
naw i just want something simple not really into chipping n stuff something like stock but a little bit better with a little bit more horse power but i dont have money for a b16 and everything else and my car is salvage title so yea or am i just better or getting stock ? i really dont want to but .....
Old Jul 10, 2007 | 06:21 PM
90goldhatch's Avatar
http://www.thezcr.com <that should solve all your problems
ProchargedSN95
Nov 24, 2005 06:36 PM
Turbo Dan
Apr 11, 2005 03:02 PM
WhatThaFrig
Jan 16, 2003 03:14 AM
Hondasaurs
11
Dec 1, 2002 12:29 PM
