trans "wear" normal?
Old Jul 10, 2007 | 11:55 AM
-DC2-'s Avatar
Default trans "wear" normal?
so, i changed my trans fluid after a month as i wanted to confirm all 2 quarts were still in it after a leak from an HPDE. anyway... i found something i'm pretty sure is even worse....
tons of super-tiny metallic flakes in the fluid. it's completely saturated with it
the tranny still shifts perfectly and has no grinds or notchiness at any RPM.
any thoughts other than "time for a rebuild"? is this even remotely normal? trans has 150k on it.
Old Jul 10, 2007 | 12:12 PM
Padawan's Avatar
Darth ModerVader
Default Re: trans "wear" normal? (-DC2-)
If the transmission is still operating perfectly, I would not concern myself with it. Just refill it with Honda MTF and enjoy.
Old Jul 10, 2007 | 01:03 PM
hitekper4mance's Avatar
Default Re: trans "wear" normal? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If the transmission is still operating perfectly, I would not concern myself with it. Just refill it with Honda MTF and enjoy. </TD></TR></TABLE>
I'm no mechanic but I always like to put post. I agree with Padawan. If its tiny shiny reflections, I wouldnt worry. As long as there are no metal slivers and shavings, or worst case chunks, I think its normal. what tranny is it? my teg takes like 2 1/4- 2 1/2 qts
Old Jul 10, 2007 | 01:59 PM
DecentCivicZ6's Avatar
B A N N E D
humm...well I changed mine once and it looked the same, and few weeks later....input shaft bearing came apart on me, I could see where it had been rubbing and rubbing and rubbing, and finalyl came aaprt...might nto have had nothing to do with the shavings....But mine was the same...i was almost a perfect paint color, lol
Old Jul 10, 2007 | 02:25 PM
-DC2-'s Avatar
it's a GSR trans. i have only owned the car for 2 months, so i have no idea how it was treated before i got my hands on it.
there is no slivers/chunks/etc in the fluid. only the tiny flakes... like a pearl in paint.
helms specs are 2.2qts for refill, 2.3 for rebuild.
i have confirmed with a local well-respected trans technician that i have absolutely no typical ISB failing noise. no knocking startup, no grinding idle that goes away with clutch release, etc
Modified by -DC2- at 6:36 PM 7/10/2007
Old Jul 12, 2007 | 06:36 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (-DC2-)
I reccomend throwing some Honda MTF in it and shifting smooth
SHPrelude00
Apr 19, 2018 01:36 PM
D50boy
Jul 27, 2006 09:50 PM
honda95civic
Sep 23, 2004 06:26 PM
accordinglyevil
Aug 5, 2004 11:46 AM
VacantBanana
May 15, 2004 09:31 PM
