Vaccum leak testing
Old Jul 10, 2007 | 10:34 AM
racing27's Avatar
Default Vacuum leak testing
What is the best methods or tools for checking vacuum leak?
Thanks HT genius.
Old Jul 10, 2007 | 11:06 AM
t0p_sh0tta's Avatar
Default Re: Vacuum leak testing (racing27)
Testing to see if you have one, or actually locating the leak?
Old Jul 10, 2007 | 11:18 AM
thesmogman's Avatar
The best would be a smoke machine.
However you can have the car running and spray carb cleaner around and if the rpms move then you found it.
Old Jul 10, 2007 | 11:50 AM
racing27's Avatar
Default Re: Vacuum leak testing (thesmogman)
I'll try the carburator cleaner. I am having problem with idle. I have to step on the throttle or gas to keep it idling. any idea why the idle is not steady?
thanks so much.
Old Jul 10, 2007 | 11:57 AM
uneek360's Avatar
have you checked all your vacuum lines ? Clean your iacv, these are good starts.
Old Jul 10, 2007 | 12:03 PM
racing27's Avatar
Default Re: Vacuum leak testing (uneek360)
I have not check my IACV. I'll do that next.
thanks again.
weaslehunter1
Jan 26, 2015 03:49 PM
turboteg7
May 9, 2009 01:56 PM
cmsoard
Apr 1, 2009 10:15 AM
PhilMac
Jan 14, 2008 11:35 AM
sik_sol
May 25, 2006 01:56 PM
