3 10" subs but what amp?
My question is should I get 1 strong 1 channel amp and bridge all 3 subs or get 3 regular 1 channel amps to power them indidvual?
Ill be running either 3 of these if they will clear the stealth box
http://www.radiomancaraudio.co...1000D
Product ID: NKW1000D Category: Nakamichi Subwoofers
Nakamichi SP-W1000D DVC Subwoofer
Description: SUBWOOFER SPECIFICATIONS Diameter: 10" 254mm Sensitivity: 86.5dB Power Handling: Watts RMS: 350 Watts Watts Peak: 550 Watts Frequency Response: 20Hz-500Hz Nominal Impedance: 2 x 6 Ohms Cone Material: Pulped Paper Basket Material: Aluminum Surround Material: 2.25" Rubber Spider Material: Nomex Magnet Weight: 120oz. Voice Coil: Dual Free-Air Resonance (Fs): 34.390Hz Mechanical Dampening (Qms): 6.734 Electrical Dampening (Qes): .743 Total System Dampening (Qts): .669 Voice Coil DC Resistance (Re): 5.6 Ohms (Dual) Equivalent Acoustic Volume (Vas): 41.853 Liters Effective Diaphragm Area (Sd): 33.006 sq. meter Linear Coil Excursion (Xmax): 12.5mm Half Space Output Level (SPL): 86.5dB Energy Bandwidth Product (EBP): 46.30 Mass of the Moving System (Mms): 79.163 grams
if not ill use these
http://www.radiomancaraudio.co...W104S.
Product ID: NKW104S Category: Nakamichi Subwoofers
Nakamichi SP-W104S SVC Subwoofer
Description: Diameter: 10" 254mm Sensitivity: 88.7dB Power Handling: Watts RMS: 250 Watts Watts Peak: 400 Watts Frequency Response: 25Hz-500Hz Nominal Impedance: 4 Ohms Cone Material: Polypropylene Basket Material: Steel Surround Material: 2" Rubber Spider Material: Poly/Cotton Magnet Weight: 100oz. Voice Coil: Single Free-Air Resonance (Fs): 25.612Hz Mechanical Dampening (Qms): 4.409 Electrical Dampening (Qes): .335 Total System Dampening (Qts): .312 Voice Coil DC Resistance (Re): 3.2 Ohms Equivalent Acoustic Volume (Vas): 75.656 Liters Effective Diaphragm Area (Sd): 33.006 sq. meter Linear Coil Excursion (Xmax): 10.5mm Half Space Output Level (SPL): 88.7dB Energy Bandwidth Product (EBP): 76.45 Mass of the Moving System (Mms): 79.163 grams
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Just get one strong amp, alot easier on the wiring and space. make sure you get on that matches the load for your speaker power wise.
Get one good monoblock amp that will make 1000ishrms @1ohm, 1/0 wiring, and the other stuff you need. Don't skimp on wiring, get quality stuff.
I'd recommend Diamond Audio amps from personal experience (Been working in the industry for 2 1/2 years)
In the past i have had Alpine, MTX and JL Audio amps... I'm a huge fan of JL audio amps after buying them. They are a little bit more money, but the quality is there. I have a 500/1 watt amp from JL and it sounds cleaner and louder than a 750w alpine.
I would also get a powerful mono amp and bridge the 3 subs. Wiring is a huge part though, definatly get good wiring, or your amp wont be at full potential.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ »</TD></TR><TR><TD CLASS="quote">i looked at a few diamond amps didn't really like them for some reason. i was thinking of 3 10" JL subs with the 1000/1 JL amp.</TD></TR></TABLE>
As long as you don't end up with a 1ohm final impedance, that would work too. From what I remember the 1000/1 is only 1.3 ohm stable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> That would be 1.5 ohms, the slash series amps regulated power supplies allows the amps to make rated RMS power into 1.5 - 4 ohms @ 11V - 14.5V., anything lower then 1.5 ohms and the amp will go into protection mode, they sound the best connected to a 3 - 4 ohm load.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdh061 »</TD></TR><TR><TD CLASS="quote">In the past i have had Alpine, MTX and JL Audio amps... I'm a huge fan of JL audio amps after buying them. They are a little bit more money, but the quality is there. I have a 500/1 watt amp from JL and it sounds cleaner and louder than a 750w alpine.
I would also get a powerful mono amp and bridge the 3 subs. Wiring is a huge part though, definatly get good wiring, or your amp wont be at full potential. </TD></TR></TABLE>
would hte JL 500/1 work with 3 10W3V2? i know the 1000/1 will work but wondering if i can save a few hundred by buying the 500/1. i know the W3 is rated at 300rms each so i would need something in the 900rms area but from what i heard the 500/1 is under rated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ »</TD></TR><TR><TD CLASS="quote">would hte JL 500/1 work with 3 10W3V2? i know the 1000/1 will work but wondering if i can save a few hundred by buying the 500/1. i know the W3 is rated at 300rms each so i would need something in the 900rms area but from what i heard the 500/1 is under rated.</TD></TR></TABLE> It is not under rated, it makes 500W RMS, [+/- a couple of watts], the regulated power supply is designed so the amp makes 500W at 1.5-4 ohms and 11V-14.5V.
Although the 500/1 would drive the 3 subs it is really way under-powered, the 1000/1 would be a better amp,
BTW when you get the subs, get the 10W3v2-D4, [DVC 4 ohm] and wire the VCs in series and the subs in parallel, you will end up with about a 2.5 ohm load.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> It is not under rated, it makes 500W RMS, [+/- a couple of watts], the regulated power supply is designed so the amp makes 500W at 1.5-4 ohms and 11V-14.5V.
94 </TD></TR></TABLE>
thanks!
94 </TD></TR></TABLE>thanks!
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
