After replacing the ac belt on a eg
Old Jul 10, 2007 | 04:51 AM
crazyguy's Avatar
Default After replacing the ac belt on a eg
it will make squeaky sound every once in a while while driving it..
is it because the ac belt is over tighten or not tight enough?
thanks
Old Jul 10, 2007 | 04:58 AM
nsxmatt's Avatar
Either. Go check it.
Old Jul 10, 2007 | 05:01 AM
Padawan's Avatar
Darth ModerVader
Default Re: After replacing the ac belt on a eg (crazyguy)
Also make sure that both the pulley and the belt are clean.
Old Jul 10, 2007 | 05:14 AM
silver spur's Avatar
maybe your belt tensioner is starting to sieze up? when tigten the belts, you should barely able to twist it side to side.
sebTeggy
Nov 7, 2011 01:22 PM
b18c196
Aug 3, 2006 12:59 PM
ALMXDUPINTEGRA
Aug 17, 2005 03:54 PM
shyboi4u
Aug 4, 2005 03:54 PM
EGcivicBoy
Nov 11, 2003 05:21 PM
