b18c5 or h22 swap for my 95 civic ex coupe
Old Jul 9, 2007 | 08:28 PM
Exvtec king's Avatar
Default b18c5 or h22 swap for my 95 civic ex coupe
i wanted to know which swap is better a b18c5 or a h22 swap for my 95 civic ex coupe
Old Jul 9, 2007 | 08:39 PM
TeeMal's Avatar
either would be fast but id go b18c5 because of pure rarity! dont see many so it would def turn more heads than an h22
Old Jul 9, 2007 | 08:43 PM
01_CLtypeS's Avatar
Default Re: b18c5 or h22 swap for my 95 civic ex coupe (Exvtec king)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exvtec king &raquo;</TD></TR><TR><TD CLASS="quote">i wanted to know which swap is better a b18c5 or a h22 swap for my 95 civic ex coupe</TD></TR></TABLE>
id go with the c5 or the JDM ITR b18c thats what i have in my 99 coupe fun swap
Old Jul 9, 2007 | 08:50 PM
SiRek4
Guest
Posts: n/a
Default Re: b18c5 or h22 swap for my 95 civic ex coupe (01_CLtypeS)
B series for sure, dont let people pump you up on the H2B thing, Prelude motors suck, I had one and I was gonna trade it for a GSR.
Old Jul 9, 2007 | 08:51 PM
rbolander's Avatar
h22 swap- $2000-$2500
b18c5 swap- $4000-$5000
b18c1 swap- $2800-$3500
a gsr with an aftermarket IM, TB, CAI, header, and exhaust would be faster than a type-r or h22 swap and is also a better platform for turbo, depending on what your future plans are. also, with all of these mods including the actual swap, it would cost around the same as just a type-r swap.
I did it in my 97 civic and it was well worth it. after a good tune, it was dyno'ed at 220hp but i also had adjustable cam gears and was able to tweak that a little bit.
but to each his own. good luck man.
Old Jul 9, 2007 | 09:01 PM
CapnKrunch's Avatar
Default Re: b18c5 or h22 swap for my 95 civic ex coupe (rbolander)
https://honda-tech.com/zerothread?id=626892
search
In my opinion if I were to choose between the 2 I would get the H22 with a B series tranny. It would be the fastest out of the box by far and much torquier than a b18 and is about the same weight as a b18 also. Can't go wrong.
Old Jul 9, 2007 | 09:57 PM
H22Ej1's Avatar
Shenanigans
Default Re: b18c5 or h22 swap for my 95 civic ex coupe (CapnKrunch)
h series i just got mine done and its damn nice
if u want rarity euro r h22 thats what i rock
Old Jul 9, 2007 | 10:34 PM
user 98292739's Avatar
wow the comments....
if those were the choices i would go H22 with B motor and itll be faster then the other two motors N/A bolt on no contest...and cheaper...
whoever said H2B does not know what they are talking about.
Old Jul 9, 2007 | 10:54 PM
dannis.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRek4 &raquo;</TD></TR><TR><TD CLASS="quote">B series for sure, dont let people pump you up on the H2B thing, Prelude motors suck, I had one and I was gonna trade it for a GSR.</TD></TR></TABLE>
you my friend are stupid. how does the prelude motor suck? lets hear why you think the h2b sucks.
now for exvtec king i'd personally recommend doing a h2b swap cause its a really fun motor. and it would be about the same price your spending for the type r swap.
Old Jul 10, 2007 | 04:01 AM
symph0ny's Avatar
Depends on what you want out of the car. The H22 has a better low end because it's higher displacement. Everyone is saying that it sucks because the high end is nowhere near as good as a b18c5.
Personally I'd go with a B18C1, it'll save you a fair amount of work by not changing the OBD version. You could also turbocharge it more practically later, if you decided that you want more torque on the bottom end.
Old Jul 10, 2007 | 05:33 AM
95ProjectEJ1's Avatar
^^ Do you have the money right now for either of these swaps or is it just a general question?
Old Jul 10, 2007 | 05:44 AM
4thgenx42's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exvtec king &raquo;</TD></TR><TR><TD CLASS="quote"> I wanted to know which swap is better a b18c5 or a h22 swap for my 95 civic ex coupe</TD></TR></TABLE>
Well I'd go with the B18c5 motor. That motor is pure sex. But seriously I'd do a B16 motor instead and look into installing a turbo kit.
Old Jul 10, 2007 | 05:54 AM
Boost_V's Avatar
Default Re: (4thgenx42)
you say you want to know which swap is BETTER. Neither really. It comlpetely depends on what you want or will be using it for. I've heard the H2b is very impressive and wll worth the time/money. Great for DD. I've heard good things about the B18C5 also, but imo, not worth it unless you are set on sticking with NA. A b18 or B16 for that matter with a turbo kit would please you also, but will definately feel different from the H. I'm just waiting for ek forever guy to show us all up of why the h2b is best
Old Jul 10, 2007 | 08:11 AM
CDizzl's Avatar
Well,
Let me ask you this, do you know why you want to swap? If so what are you going to set up the car for?(drag, street, autocross, or road racing). For a straight line it would be best to go with more top end, more motor weight will help with traction, but of course your tourqe. I myself am building a 93 honda civic ex, im swapping in a b18b1 the hp numbers are a little lw but the tourqe is great, im going to convert to a vtec, im going to bost it and do some other misc. building. But im setting up for autcross. For this you want the most tourqe for the least amount of Rpm. plus the motor is lighter than others. Street and roadracing, you can get away with anything but of course you want your tourqe for lower Rpm, also study what you want to do, i talked to a civic guru, he was telling me to look into the earlier H23 but i reminded him i like to hit hard corners and stick, nobody should be condemed for what they say about what motors, its all about your passion and how you choose to drive your car. Id go with the b for less weight, the h for more top power.
Old Jul 10, 2007 | 08:21 AM
B_Something's Avatar
https://honda-tech.com/zerothread?id=979961
Please use the wonderful search features.
H22 may be cheaper, B18C5 may be easier.
Old Jul 10, 2007 | 08:45 AM
MagnaniEG6's Avatar
Default Re: b18c5 or h22 swap for my 95 civic ex coupe (B_Something)
wow this been covered before. My friend had an H23 with and H22 vtec head thing hauled *** but when he race my friends EG ITR cams, intake, exhaust he lost mainly traction probs and both swaps cost the same. Good motor idk if I would do it since swap is harder. Anyone throw a Kswap idea here yet?
menacehect
Honda Civic (2001 - 2005)
Nov 2, 2008 08:56 PM
Dav94Lx
Feb 16, 2008 06:56 AM
1fst4dr
Mar 28, 2003 04:16 PM
