upper a arm stripped
Old Jul 9, 2007 | 08:11 PM
beatthisspeed69's Avatar
Default upper a arm stripped
well i was driving my car gooin about 15 mph and the bolt for the upper a arm i think thats wat its called fell off.....and so i took it home and found out that where the castle nut bolts on to is completly stripped and that i can put a bolt on there for my life...so my question is do i have to replace my whole a arm or is there another way...thnx ahead of time
Old Jul 9, 2007 | 08:31 PM
bmg123's Avatar
Default Re: upper a arm stripped (beatthisspeed69)
maybe so, or if your car is a 90-91, you could replace just the ball joint.. Maybe it would be a good time to put on an SPC ball joint style camber kit if you were thinking of putting a camber kit on some time anyway....
but if you have to replace the upper arm it is pretty easy to do, and they are cheap and plentiful in junkyards
Old Jul 10, 2007 | 09:11 AM
wiZCo's Avatar
Stouts 'n' Scotch
It's probably going to be easier just to replace the whole a-arm.
Old Jul 10, 2007 | 12:28 PM
LilJonWask's Avatar
Default Re: (wiZCo)
When my castle nut fell off my lower control arm (the haynes manual said you had to get the castle nut just above the cotter pin hole so thats what I did but now I know you gotta tighten that bitch) , the ball joint thread got fucked up... but I just used a tap and die set and it was all gravy.
Old Jul 11, 2007 | 09:03 PM
how do you replace just the ball joint cuz i have a 91????
Old Jul 12, 2007 | 02:32 AM
Default Re: (beatthisspeed69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 &raquo;</TD></TR><TR><TD CLASS="quote">how do you replace just the ball joint cuz i have a 91????</TD></TR></TABLE>
does n e one no how to just replace the ball joint on the upper a arm so i dont have to go out and buy a new a arm...(very low on money)
matryx
Jul 25, 2008 09:14 PM
russianswty
Feb 18, 2007 02:24 PM
The DX Rex
May 29, 2005 05:12 PM
Frosty_spl
Oct 29, 2002 11:05 AM
