Top Mainshaft Bearing Play.....Normal?
I opened up my tranny and have noticed a decent amount of play in the top mainshaft bearing. I would say it moves about 0.25'' up and down but it is very tight side to side. I searched and found a few results describing the same thing but no answers about if this is normal. I would rather not replace it since it is $50 if it is in good shape.
I called gearspeed to ask if this was normal but the guy wasnt much help at all. When i asked if any play was normal he said that his definition would be different than mine and that he couldn't answer that question over the phone, which i understood. But then he continued to talk down to me. He acted as if he was the god of Honda transmissions (which he may be) and that i was too incompetent attempt to do transmission work myself (which is incorrect).
Anyways, back to the point. Is the play normal?
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">normal.........
angular thrust bearing, it relies on proper shimming and the thrust washer next to the input shaft bearing for proper preloading.</TD></TR></TABLE>
ekhaze
Transmission & Drivetrain
Mar 25, 2011 01:57 PM
Pbanto
Apr 8, 2009 05:07 AM
Wes V
22
Oct 25, 2003 12:51 PM
