smoke coming out by the turbo
well i started to drive it quite a bit and maybe using 4 lbs of boost and noticed that sometimes there is smoke coming out where my turbo is. it is somewhere around that regin. can anyone help...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceKillinSI »</TD></TR><TR><TD CLASS="quote">Is the oil line going to your turbo leaking?</TD></TR></TABLE>
X2, give that a check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">at higher RPMS? if not, it's a bad tune, or if that you haven't tuned it at all.</TD></TR></TABLE>
How the fuuck would tune have anything whatsoever to do with an oil issue?
i looked at it, and i think i know why it is smoking a little. i looked where the oil line is, where it is tapped into the oil pan and there is a leak, but not oil leaking out. i looked at it and seems like where the hose going to the oil pan there is tape wrapped around the line. so i think it has a small cut in it and tape is just keeping it from pouring out. anyone help me if this is correct.
90hatchblack
Mar 1, 2007 07:57 PM
