B18C1 Civic valve problem
was driving one day and started to get a bad ticking sound from the valves so when I got home decided to do a valve adjustment so pulled off the valve cover and found this...
not sure if this is a common problem or not and also found this in the first cylinder
any fixes or new head perhaps?
The first two pics of the head there is nothing wrong. All GSR heads look like that. I believe they crack out those two spots after casting to help wash out all the sand.
Every GSR head I have had looked like that so trust me it is normal.
The 3rd pic looks like the valve adjustment nut came off, you gotta find that bad boy, hopefully it just fell down into the oil pan, check head, if you don't find, check oil pan AND pickup (it might be stuck on the pickup screen)
Now the spark plug is bad, you definitely haven't replaced them recently.
The valve may have come in contact with the piston if there was too much lash....
I found the nut as soon as i pulled of the cover it was resting by the valve spring and thanks for clarifying on the cracked spots wasn't too sure
and the plug just recently got the car a month ago so haven't really undergone any maintenance.
for the adjustment nut if I put it back on and adjust it would I run into the same problem? could the valve possibly be bent from coming in contact with the piston? thanks
Adam
and the plug just recently got the car a month ago so haven't really undergone any maintenance.for the adjustment nut if I put it back on and adjust it would I run into the same problem? could the valve possibly be bent from coming in contact with the piston? thanks
Adam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki »</TD></TR><TR><TD CLASS="quote">ur basically gonna need a new head man cause ur head is crack..</TD></TR></TABLE>
please dont post anymore.
the first 2 pics are normal casting marks. since you found the nut, reinstal it and do an adjustment and see how she runs. the spark plugs need to be replace, when is the last time they were? also is that hair on the plug?
so reinstalled the adjusting nut and adjusted all of the valves so the valve tick went away and got some new NGK platinums installed and decided to change the oil well im at it so all is well thanks for the information guys
but one last question should I be worried about the adjusting nut coming loose again?? is this a common problem?
Adam
but one last question should I be worried about the adjusting nut coming loose again?? is this a common problem?Adam
If someone did a hack job adjusting the valve, they could have over torqued them, and they backed off.
The plug looks like you are burning a bit of oil, are you putting additives in your fuel by any chance?
no I haven't put any additives in my fuel and have always ran Chevron 91 octane and I was sure i was burning oil about every 3000 miles when I am due for an oil change my oil light will flicker on and off and when I check it i am low
unknown0001
11
May 11, 2007 03:43 PM
