1 gallon fuel cell placement
Old Jul 9, 2007 | 02:57 PM
Chiovnidca's Avatar
Default 1 gallon fuel cell placement
I'm wanting to run a separate fuel system for runs at the track. This looks like the only place to put it. Ok or not?
Gonna relocate the battery here.
Old Jul 9, 2007 | 03:09 PM
4-ageTOg63's Avatar
Default Re: 1 gallon fuel cell placement (Chiovnidca)
Is it just me...or does anyone else see a problem with running a seperate gas tank under the hood, I.E. safety concerns?
Old Jul 9, 2007 | 03:11 PM
Redline130's Avatar
Will that clear your tranny? What about radiator hoses and/or intercooler piping?
Old Jul 9, 2007 | 04:00 PM
Chiovnidca's Avatar
Default Re: 1 gallon fuel cell placement (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Will that clear your tranny? What about radiator hoses and/or intercooler piping? </TD></TR></TABLE>
It should have a little more than 1" clearance to the case, a little less than that at the clutch release arm. Hoses and pipes shouldn't be a problem. I'm just eyeballing things with a ruler.
Old Jul 9, 2007 | 04:06 PM
nsxmatt's Avatar
You'll get rid of the fuel filter setup so just put it there.
Old Jul 9, 2007 | 04:19 PM
Chiovnidca's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">You'll get rid of the fuel filter setup so just put it there.</TD></TR></TABLE>
Right above the differential? A chunked diff makes for a bad day, even more so if it chops up your gas tank. Besides i'm keeping the stock fuel system for stomping around on the street.
Old Jul 9, 2007 | 04:37 PM
nsxmatt's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Right above the differential? A chunked diff makes for a bad day, even more so if it chops up your gas tank.</TD></TR></TABLE>
How often does that happen that it's a consideration? If it's still a street car i'd be more worried about a gallon of race gas 6 inches behind your bumper but thats just me.
Old Jul 9, 2007 | 04:57 PM
Chiovnidca's Avatar
How often does that happen that it's a consideration? If it's still a street car i'd be more worried about a gallon of race gas 6 inches behind your bumper but thats just me.</TD></TR></TABLE>
It will be empty on the street, as the stock tank will be empty at the track.
Old Jul 9, 2007 | 06:23 PM
AllMoToRB18c's Avatar
It will be empty on the street, as the stock tank will be empty at the track. </TD></TR></TABLE>
what will be the purpose of that?...why not keep the stock tank and put in very little fuel when at the track...if youre tryin to save weight...keeping the stock tank and adding a fuel cell doesnt make sense to me..usually ppl add a fuel cell to get rid of the stock tank
Old Jul 10, 2007 | 07:52 AM
Chiovnidca's Avatar
Default Re: (AllMoToRB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMoToRB18c &raquo;</TD></TR><TR><TD CLASS="quote">
what will be the purpose of that?...why not keep the stock tank and put in very little fuel when at the track...if youre tryin to save weight...keeping the stock tank and adding a fuel cell doesnt make sense to me..usually ppl add a fuel cell to get rid of the stock tank</TD></TR></TABLE>
I want to run expensive race gas at the track, dont want it to get diluted with the cheap stuff that wont come out of the tank.
Old Jul 10, 2007 | 10:03 AM
raene's Avatar
You could run a valve to run the stock tank dry at the track via the fuel pump... or even a small drain would work nicely. Just throwing some more thoughts out there I don't know about the placement of the tank, sorry.
Old Jul 10, 2007 | 11:56 AM
I want to run expensive race gas at the track, dont want it to get diluted with the cheap stuff that wont come out of the tank.</TD></TR></TABLE>
if you drain the tank then all of it should come out so it will be ok to run the race gas
Old Jul 10, 2007 | 02:32 PM
Chiovnidca's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">You could run a valve to run the stock tank dry at the track via the fuel pump... or even a small drain would work nicely. Just throwing some more thoughts out there </TD></TR></TABLE>
I was planning on using the pump to get it out.
if you drain the tank then all of it should come out so it will be ok to run the race gas</TD></TR></TABLE>
It wont all come out unless you pull the tank out. It sits over in the sides and the low spots. At least 1/2 gallon.
Old Jul 10, 2007 | 02:45 PM
h22crxpwr's Avatar
It wont all come out unless you pull the tank out. It sits over in the sides and the low spots. At least 1/2 gallon.[/QUOTE]
if your car can run and drive fine on pump gas then mixing a measly 1/2 gallon or less with some 100 octane won't hurt you any... why waste time on a separate fuel cell??? what is your setup anyway N/A? turbo? and what octane are you planning on running?
Old Jul 10, 2007 | 03:48 PM
dkim48's Avatar
with the money saved without buying the extra fuel cell/pump/filter, etc...you could've filled your tank with race gas more then enough times to race.
Old Jul 10, 2007 | 06:32 PM
SOHCboost's Avatar
Why dont u just sump it and be done with it
Old Jul 11, 2007 | 03:23 AM
Chiovnidca's Avatar
Default Re: (SOHCboost)
Too late, already got the stuff. I'll probably end up ditching the stock tank and cut down on the street runs.
Old Jul 11, 2007 | 07:00 AM
ExVtec's Avatar
Yea, seriously not worth the hassle or extra $$.
If you are dead set on doing that, then mount it in the trunk and plumb it from there.
BLaCKWiDoWSi
Jan 20, 2010 09:09 PM
b16b18
Aug 26, 2008 12:49 PM
SkertySkerty
Jul 13, 2007 07:13 AM
integlspwr2k
10
Sep 8, 2004 03:39 PM
im sabah
Welding / Fabrication
Aug 12, 2004 11:51 AM
