26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM?
Old Jul 9, 2007 | 01:46 PM
jasonp's Avatar
Default 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM?
I in the process of building my 95 Civic Coupe for the Hot Rod Class and I mounted and put my Wheels and Tires on and I had to notch the bottom of the fender wells so I could turn the wheels... anyone else with this problem and how did you fix it..? thanks...
Old Jul 9, 2007 | 01:47 PM
MrParks's Avatar
Default Re: 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM? (jasonp)
i have run 26x8.5x15 and never had a problem
but then again i have an integra so the wheel wells and a bit bigger
Old Jul 9, 2007 | 01:54 PM
jasonp's Avatar
Default Re: 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM? (rota92)
What I'm talking about the lower rocker panel area where the mud flap would go and I also have a one piece front end..
Old Jul 9, 2007 | 01:57 PM
Fitti's Avatar
post a pic so everyone knows what you are talking about
Old Jul 9, 2007 | 02:17 PM
jasonp's Avatar
thanks, I just cut them and put some small plate there.. it looks good, I was just wondering who else has done this...
Old Jul 9, 2007 | 02:22 PM
DaveF's Avatar
Default Re: (jasonp)
we cut about 2inch's at least, into the rocker. the side skirts are alot shorter now
Old Jul 9, 2007 | 02:23 PM
jasonp's Avatar
Default Re: (dturbocivic)
did you weld plates or just left them open..?
Old Jul 9, 2007 | 02:27 PM
DaveF's Avatar
we made wheel tubs, we cut into the firewall/ a pillar, up and around, then filled it back in with sheetmetal.
Old Jul 9, 2007 | 06:58 PM
jasonp's Avatar
also looking for pics
Old Jul 9, 2007 | 07:16 PM
airshifter's Avatar
had to cut ours for the 24.5's and a little more for the 26's, We used a custom bogart with the 26's so the wheel didn't stick out as far as our Welds with the 24.5's
Old Jul 9, 2007 | 07:28 PM
ykracing's Avatar
Default Re: (airshifter)
yes, I had the same issue..
Old Jul 10, 2007 | 02:29 AM
DaveF's Avatar
this is an hatchback sideskirt on here
Old Jul 10, 2007 | 04:06 AM
Adriano's Avatar
Default Re: 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM? (dturbocivic)
The CLM guys and I run 26x8.5x15 on a 15x7 run all the times. I run it on my 96 civic without any problem. You just have to raise the car so it clears.
Adriano.
Old Jul 10, 2007 | 04:09 AM
Adriano's Avatar
Default Re: 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM? (Adriano)
here's a pic
The 26x10x15 fits but will rub once you turn the wheels.
Adriano
Old Jul 12, 2007 | 07:47 PM
dester223's Avatar
haha, it looks like you guys lost a chunk of the bumper like I did also
Old Jul 12, 2007 | 07:51 PM
ykracing's Avatar
Default Re: 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM? (dester223)
I think thats a reflection of the cone..
Old Jul 13, 2007 | 06:26 AM
.RTErnie's Avatar
Default Re: 26" SLICKS WITH 15" RIMS WHO'S RUNNING THEM? (ykracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ykracing &raquo;</TD></TR><TR><TD CLASS="quote">I think thats a reflection of the cone..</TD></TR></TABLE>
naw....right above that. he's missing a part of his bumper.
I ran 25x9x13's...rubbed as soon as you turned.
Old Jul 14, 2007 | 03:53 PM
dester223's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">The CLM guys and I run 26x8.5x15 on a 15x7 run all the times. I run it on my 96 civic without any problem. You just have to raise the car so it clears.
Adriano.</TD></TR></TABLE>
Hey, I also noticed you have a LS web wheel on there. Which is 15x6. not 15x7. What kinda 60 foots are you hitting with them?
Old Jul 14, 2007 | 05:59 PM
Adriano's Avatar
The bumper is missing a piece but it's not from the 26s, I put the bumper back in in rush using zipties and it got caught while street driving . The best 60ft I got with them was a 1.61 and average mid-1.6.
Adriano
Old Jul 14, 2007 | 06:04 PM
nsxmatt's Avatar
Most people are running a drag racing rim which will stick out more and rub when turning unlike the stock offset LS wheel you posted.
Old Jul 14, 2007 | 09:42 PM
SlicksMH's Avatar
WOW and my M&H 8.5/26-13 would work the best. The most tracktion on the track and the best 60ty's.
John
M&H
Boosted_01 R
Jul 17, 2009 09:45 PM
b18c1vc97
Jul 23, 2006 10:09 PM
TurboLaxx
Suspension & Brakes
Nov 20, 2005 10:15 AM
chriskona
Welding / Fabrication
May 24, 2005 09:34 PM
All Motor R
Jul 31, 2002 01:45 PM
