finishing my turbo set up .. i have a few questions that i need answered
Old Jul 9, 2007 | 01:36 PM
pjr710's Avatar
Default finishing my turbo set up .. i have a few questions that i need answered
i just recieve a wastegate,bov,intercooler,piping,oil pan, oil lines, and turbo
i am ordering a mani/downpipe/dumptube combo very shortly
my question is this. I know i have to buy injectors for sure, but some people say that my stock 97 civic fuel pump is good enough and that a walborough 255 is overkill. I'm worried about running rich with the 255, but if i get a tune do i need to worry about that?
I am going to be shooting for 200whp. Will i definately need to upgrade my clutch right away? its stock
and i realized today that i need to connect my bov and wastegate to something else other than the piping and the manifold. where do i get these lines and wehre do they go?
and also, i do not have any gaskets or hardware right now except for the stuff that came with the oil lines. Will i need to buy a gasket for my turbo, wastegate, or anything else
Old Jul 9, 2007 | 02:24 PM
RCautoworks's Avatar
Default Re: finishing my turbo set up .. i have a few questions that i need answered (pjr710)
Don't worry about running rich, if your getting it tuned they will take care of that. The clutch will be ok, but in the long run you might want to replace it. Remember, always go bigger then smaller.
Old Jul 9, 2007 | 02:31 PM
pjr710's Avatar
Default Re: finishing my turbo set up .. i have a few questions that i need answered (RCautoworks)
Alrite, i will probably buy a clutch b/c i have the money i just cant install it.
Will i need an oil catch can and colder spark plugs as well?
Old Jul 9, 2007 | 02:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">Alrite, i will probably buy a clutch b/c i have the money i just cant install it.
Will i need an oil catch can and colder spark plugs as well?</TD></TR></TABLE>
Some tuners suggest colder plugs, and it would be a smart thing to run a catch can.
Old Jul 10, 2007 | 07:54 AM
esedulerp5tenin's Avatar
new colder spark plugs are only like $15, and they are recommended. ngk bkr-7e's are VERY common for turbo hondas
its better to run rich than lean
walbro 255... $95
DSM 450cc injectors... like $40 used
you can use fuel line for the tubing for the WG and BOV. i think its 5/8" outer diameter (???)
BOV line goes to intake manifold.
if your IC piping or turbo has a nipple on it to connect a hose to, you can attach the WG hose there. if not you can Tee it into your PCV line like i did
you should already have a gasket between your header and your head, so you can reuse that one when you put the turbo manifold on. there should however be a gasket between the manifold and the turbo, the manifold and the wastegate, turbo and downpipe, wastegate and dumptube, and downpipe to exhaust.
your also gonna need the bolts for turbo-manifold, wastegate-manifold, wastegate-dumptube, and downpipe-turbo
phew
sspbteg00
Feb 16, 2007 12:38 AM
andreysibiris
13
Jan 17, 2006 12:03 PM
hot93honda
Feb 18, 2005 01:28 PM
ditsboy
Nov 1, 2004 06:28 AM
napester21
Aug 20, 2003 10:18 PM
