Distributor problems...
Old Jul 9, 2007 | 10:23 AM
DSBP1's Avatar
Default Distributor problems...
Hey Guys,
First off, I wanna thank you guys for helping me with the information about my intake..
but now, I have a distributor problem...my distributor is not working..this like the third distributor that I change..I don't know if there is a problem in my car that is messing up the distributor or the guy that is giving me the distributors are giving me not so good distributors.
I need some help, what you guys think it might be bad distributors from my friend or my car is destroying the distributors...
btw, I have a 94 civic DX 1.5CL
Old Jul 9, 2007 | 12:27 PM
DSBP1's Avatar
Uppin..
Old Jul 9, 2007 | 12:56 PM
minime-civic's Avatar
* B A N N E D *
Default Re: (DSBP1)
make sure your ecu is plugged in, does it run? you need to give more info, so i can figure out your problem
Old Jul 9, 2007 | 01:07 PM
DSBP1's Avatar
well we moved it from one place to another by using a screw driver to one of the cables that goes to the engine..so it can turn on..
it turns on every once in a while...plus when I drove it..you could tell that the car was running low on power....my mechanic checked it out and said that it was the distributor....but my problem is that I don't know if there is a problem with the distributor or a faulty wiring within the car that is messing up the distributor..because this like my third distributor..
Old Jul 9, 2007 | 01:09 PM
* B A N N E D *
Default Re: (DSBP1)
do you have msn? i can talk you through this.
Old Jul 9, 2007 | 01:48 PM
GumBottomBoosted's Avatar
Default Re: (DSBP1)
when it was "running low on power" did it sound like it was misfiring? if this is your third dizzy then it could be some wiring, check your plug wires.
more info
Old Jul 11, 2007 | 02:27 AM
zcsport's Avatar
Default Re: (GumBottomBoosted)
well i think i had the same problem so i would stay in this thread too..i always had code 8 and i changed my distributor once but i still having the code and cel 15 shows up sometimes but not always..and over all my MPG is so low i get 10- 20 MPG..i know i have a good oxygen sensor because i just had a shop that did the job for me!!and i heard about if the rotor is not spin free or i had bearing worn out in my distributor i'll get this result and while when i'm driving i hear some noise comes from something under my hood,so any idea???
Modified by zcsport at 3:39 AM 7/11/2007
DRAGANDB1
Aug 9, 2018 06:19 PM
Dnelle95
11
Sep 23, 2011 08:36 PM
minvi
Mar 7, 2011 06:04 PM
metalgears
Aug 28, 2004 11:22 PM
sickvtec
May 21, 2004 05:41 PM
